Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 118
Thread: My new MK1 Golf 75/6
    May 2010
    SYDNEY
    We i got chance to strip down the front suspension tonight, and again it all when well and all parts look sold even the front brake backing plates!!!
    I also cleaned up the N/S wheel arch and stone chipped it.
    [/IMG]
    [/IMG]
    [IMG][/IMG]
    [/IMG]
    My daily ride also helped out with the low light!!
    [/IMG]
    Perth. WA
    When you replace the guards, use the factory zinc strips on the bolt holes, they act as a sacraficial anode for cathodic protection.
    Vw Rabbit Gti Pickup Caddy Fender Installation Kit NEW! | eBay
    the zinc tabs are available from the dealer still.
    http://www.vwwatercooled.org.au/foru...s-21212-4.html
    Third pic from the top.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    May 2010
    SYDNEY
    Yeah i have them on order part number AKL 381 035 50 form VW.
    Thanks for the link tho.
    May 2010
    SYDNEY
    strip down
    Hi Guys
    does anybody know the best place to get 2 front wheel bearing kits, front and rear suspension top mounts and also a windscreen seal from.
    Also anywhere in SYD that re-cons radiators??
    More parts came off today.
    [IMG][/IMG]
    Front panel is solid just very dirty!!
    [IMG][/IMG]
    thanks Guys
    May 2010
    SYDNEY
    So i got chance to drop the engine out today and do a little cleaning.
    [IMG][/IMG]
    Engine bay was very dirty but first clean got allot of the grit and dirt away.
    [IMG][/IMG]
    Got a spay can made up to spray the inner wing paint code L51C Miami blue (thought that was my color as it was the lightest blue in 1976, but the color was very different. The color on the car is defiantly from the factory because its under the dash, floor engine bay e.t.c.
    Any body know wot paint code or color code my car is?????
    [IMG][/IMG]
    Many thanks.
    Aug 2009
    Mk1Vw »
    There should be a sticker on the floor of the hatch with the paint colour name and code (this is probably not the case with Swallowtails...)
    The colour, to me, looks more like Lago Blue (one of my favourite A1 factory colours) but that doesn't make sense as your car was made much earlier than Lago Blue is listed.
    Did you get 75/6 from the build plate on the top of the core support/slam panel?
    Good progress btw, I think I like where this is headed.
    May 2010
    SYDNEY
    Hi Jace
    looked in the rear, no paint sticker
    Relay not sure of the colour could be Lago Blue or Whisper Blue.
    The AU compliance plate states the car was compiled on 02/1976 so the colour really is a head scratcher
    The car is definitely a factory colour the paint is too good for in not to be, even under the carpet inside.
    Help!!!
    One more picture with a closer look
    [IMG][/IMG]
    Aug 2009
    The more little bits I see of this car, the more I want it! Look how good that stock paint is!
    You could always get the colour scanned by a paint retail shop, or if you have access to a paint/panel shop just colour match it by eye (takes a bit of knowledge though)
    I know it's all about DIY (and kudos to you for that) but getting a qualified spray painter to colour match you a few liters might be your best bet if you can't get colour tester chips.
    Sydney NSW
    sweet ride mate! ive had a color match done before for a yellow color
    came out spot on and was well worth it, but with a bit of research you should be able to find a color code
    somewhere on the net
    Dec 2008
    Perth
    some of the early australian cars were painted in dulux colours, they had a little tin plate with the code stuck on the front support next to the compliance plate. looks like it's missing if it was there but might be worth looking into those colours? progress looks good!
