![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
abreut
You definitely do want to return to the tank with the mechanical fuel pump. I used a restrictor in the return line just at the t-piece leading back to the tank. Also one thing you might want to look at is the internal strainer inside the fuel tank. It is probably all gummed up after all the years of sitting and could be causing fuel starvation. You have to pull the back seat out, undo the little manhole cover, take out the fuel level sender and then get a little hook made out of a coat-hanger or something and pull out the strainer. The gauze is very fine so it blocks up easily.
