Results 31 to 34 of 34
Thread: My new MK1
  1. #31
    Dec 2013
    Quote Originally Posted by abreut View Post
    You definitely do want to return to the tank with the mechanical fuel pump. I used a restrictor in the return line just at the t-piece leading back to the tank. Also one thing you might want to look at is the internal strainer inside the fuel tank. It is probably all gummed up after all the years of sitting and could be causing fuel starvation. You have to pull the back seat out, undo the little manhole cover, take out the fuel level sender and then get a little hook made out of a coat-hanger or something and pull out the strainer. The gauze is very fine so it blocks up easily.
    Ok I will run a new return line, I'm not sure how to do it though, the return line has to be restricted but how can this be achieved? I'll have a look at the tank next week aswell.
    I spoke to the guy who done my exhaust and he said that the whistling noise is in the flexi pipe because the car isn't tuned properly and its creating that noise.
  2. #32
    Jan 2006
    Quote Originally Posted by Matti89 View Post
    I just had a brass t-piece, and the outlet that I plumbed the return line to was a bit smaller ID than the other 2 outlets. I don't think the size of the restriction is super critical. If you have a T-piece that has the same ID on all outlets, you can just make your own restrictor by putting something into the return line that has a smaller ID hole in it. Like maybe cut off a short section of a bolt that is the right ID for the hose (8mm), and just drill a 3-4mm hole up the middle of that section of bolt. That should save you from potentially flooding the carby.
    Not quite sure about the whistling sound, its not the alternator belt, or the timing belt tensioner is it? If its directly proportional to engine revs check those 2 things. Also have you got the engine breather hose back on? You will get a bit of noise out of the cam cover hole as well, but probably not a whistling sound.
  3. #33
    Dec 2013
    Nothing major to update for the time being. Still being driven almost daily. Need to change the sump gasket soon as I've got a small leak there.
    I'm still looking for a tuner to have a look at the weber thought.
  4. #34
    Oct 2014
    Edit: Just realised you're not in Victoria >.>
