Results 21 to 30 of 34
Thread: My new MK1
  1. #21
    Sep 2012
    Is this buzzing coming from the fusebox? I had this when working on my wiring, getting the headlights to work to a new separate switch (I using a different dash). The headlights are connected to the indicators so there might be a grounding issue or something unplugged, just a shot in the dark. I cant really explain how the wires are set up.. Sorry if it doesn't help but it might
    Ill attach my fusebox diagram, but you will probably have the newer model one, which is floating around the internet anyway. Im pretty sure the switch set up is the same anyway.
    Im not sure how to go about making this smaller, anyone know how to code a scroll box or spoiler on these forums?
    A
    CORRECT - 1 - Blue/White – Alternator NEW
    CORRECT - 2 - blu/brn - spare wire, linked to D4 internally
    NOTHING - 3 - blu/grn - Jumpered to pin A5
    CORRECT - 4 - blu - Alternator pin D+
    CORRECT - 5 - blu/grn - Jumpered to pin A3 ONLY GREEN
    CORRECT - 6 - blk/wht - Front left indicator
    CORRECT - 7 - brn - Horn(s)
    NOTHING - 8 - blk/grn - Jumped connector to: warm up valve, Aux air valve & fuel pump
    CORRECT - 9 - gry/blk - Left sidelight
    CORRECT - 11 - blk/yel - Horn(s)
    CORRECT - 14 - red/yel - Brake light switch
    CORRECT - 15 - blk - Reverse light switch
    CORRECT - 16 - red/blk - Brake light switch
    CORRECT - 17 - blk/grn - Reverse light switch BLACK/GRAY
    CORRECT - 18 - wht/blk - Left headlight pin 56a
    CORRECT - 19 - yel/blk - Left headlight pin 56b
    C
    CORRECT - 1 - blu/yel - Coolant temp switch - too cold
    CORRECT - 5 - brn - Windscreen wiper motor pin 31
    CORRECT - 6 - grn/blk - Windscreen wiper motor pin 53 ONLY GREEN – 9?
    CORRECT - 7 - gry/red - Right sidelight
    CORRECT - 8 - yel - Right headlight pin 56b
    CORRECT - 9 - grn - Windscreen wiper motor pin 53e GREEN/BLACK – 6?
    CORRECT – 10 – red/blk – Starter motor NEW
    CORRECT - 11 - wht - Right headlight pin 56a
    CORRECT - 12 - blu/blk - Oil pressure switch
    CORRECT - 13 - blk/gry - Windscreen wiper motor pin 53a
    CORRECT - 15 - wht/lil - Series resistance for coil BLACK/BLUE
    CORRECT - 16 - grn/yel - Windscreen wiper motor pin 53b
    CORRECT - 17 - grn/red - Windscreen washer motor
    CORRECT - 18 - blk/grn - Front right indicator
    NOTHING - 19 - blk? - Ignition Coil pin 1
    D
    CORRECT - 1 - blu/red - Dash clocks plug T14/2 (Indicator warning light)
    CORRECT - 2 - blu - Dash clocks plug T14/10 (Battery warning light)
    CORRECT - 3 - Red - Headlight switch pin 30
    CORRECT - 5 - blk - Horn relay pin 86 BLACK/BROWN
    NOT SURE - 7 - blk/wht - Headlight switch pin X WHITE/GREEN - ?
    CORRECT - 8 - blu/yel - Dash clocks plug T14/1 (Coolant temp guage - too cold)
    NOTHING - 9 - red/yel - Headlight flasher switch pin 30
    CORRECT - 10 - wht - flasher switch pin 56a BUT IS #10 – BROWN - EARTH
    NOTHING - 11 - brn – Earth SWAPED
    CORRECT - 12 - wht - hazard switch pin 49
    CORRECT - 14 - red/gry - Dash clock, Cigarette lighter ONLY RED
    NOTHING - 15 - Red - Dash clocks plug T14/4 (Rev counter)
    NOTHING - 16 - wht/grn - Rear screen heater switch pin 86
    CORRECT - 17 - wht/blk - Headlight switch pin 56
    CORRECT - 18 - blu/blk - Dash clocks plug T14/11 (Oil pressure warning lamp)
    CORRECT - 19 - blk/red - Blower motor switch pin + BLACK/WHITE
    CORRECT - 20 - blk/blu - Hazard switch pin 15
    CORRECT - 21 - red/wht - Hazard switch pin 30
    CORRECT - 22 - blu/wht - Dash clocks plug T14/3 (Main beam warning light)
    E
    CORRECT - 1 - gry/blk - Headlight switch pin 58L
    CORRECT - 2 - blk - ignition switch pin 15
    CORRECT - 3 - blk/wht/grn - Hazard switch pin 49a
    CORRECT - 5 - gry/red - Headlight switch pin 58R
    CORRECT - 7 - grn/red - Jumpered to pin E20 SWAPED WITH #8
    CORRECT - 8 - brn/blk - Wiper stalk pin J SWAPED WITH #7
    CORRECT - 9 - gry/grn - Headlight switch pin 58
    NOT SURE - 10 - yel - Flasher switch pin 56b YELLOW/BLACK AND GOES TO IGNITON PIN X
    CORRECT - 11 - brn - Horn relay pin 87 BROWN/BLUE
    CORRECT - 12 - lil/blk - Dash clocks plug T14/8 (Fuel gauge)
    NOTHING - 13 - blk/yel - Heated rear screen switch pin +
    CORRECT - 15 - ? - Wiper stalk pin 53a
    CORRECT - 16 - grn/blk - Wiper stalk pin 53e
    CORRECT – 17 – black/red - main ignition switch - NEW
    CORRECT - 18 - grn - Wiper stalk pin 53
    CORRECT - 19 - blk/wht - Hazard switch pin L
    CORRECT - 20 - grn/red - Jumpered to pin E7, Wiper stalk pin T
    CORRECT - 21 - grn/yel - Wiper stalk pin 53b
    CORRECT - 22 - blk/grn - Hazard switch pin R
    F
    CORRECT - 9 - gry/blk - Left rear light
    CORRECT - 10 - wht - heated rear screen
    CORRECT - 12 - lil/blk - Fuel guage sender
    CORRECT - 13 - gry/grn - Number plate lights
    CORRECT - 14 - red/grn - Interior light ONLY RED
    CORRECT - 15 - gry/red - Right rear light
    CORRECT - 16 - blk/grn - Rear right indicator
    CORRECT - 18 - blk - Reverse lights
    CORRECT - 19 - blk/wht - Rear left indicator
    CORRECT - 20 - blk/red - Brake lights
    G
    CORRECT - 1 - red - jumpered to pin H7
    CORRECT – 5 – wht/yel - ? Leads to nothing, spade connection near firewall NEW
    CORRECT - 6 - red/blk - Radiator fan thermo switch
    NOTHING - 7 - blk/gry - Rear wiper relay pin 53a, rear wiper motor pin 53a
    H
    NOT SURE - 3 – red – Weird box thing NEW
    CORRECT – 4 – red - ignition switch pin 30, jumpered to pin G1 NEW
    CORRECT – 5 – red – 2x wires goes to alternator NEW
    CORRECT – 6– red - Battery +ve, NEW
    CORRECT – 7– red – Jumped to G1 NEW
    Someone might find this handy anyway.
    Its the little things..
  2. #22
    Perth. WA
    Just a word of warning.
    76 and earlier cars used the fuse board / relay plate 'A' version
    Later cars used the 'B & C' version. Some of the pin out positions are different.
    Easiest way to tell if yours is an 'A' version is that it will have a large square headlamp relay on the left hand end, you will
    likely have the metal indicator switch.
    proceed with knowledge...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  3. #23
    Sep 2012
    As rocco said Mine is a 76 and doesnt use the b slot.
    Sent from my HTC_PN071
  4. #24
    Dec 2013
    Mine doesn't use the b slot aswell. I think it was a grounding issue because I recently took the cluster out to check the voltage stabiliser and when I put it back together it works fine
  5. #25
    Perth. WA
    By the A , B or C version you need to look at the part number that begins with 171.... the letter at the end is the version.
    Cheers,
    Grant...
  6. #26
    Dec 2013
    Had a new 2 inch exhaust made and installed, sounds much better now and now longer rattles
    I dont think its running 100% though. Im getting this weird whistling noise when accelerating. Heres 2 videos of the engine running, not sure if you can hear it though.
    I was also wondering if anyone know any weber tuners in sydney that can get the carb running perfectly.
    MK1 Golf - YouTube
    MK1 Golf driving - YouTube
  7. #27
    Jul 2011
    Tough exhaust! How much did that set you back?
  8. #28
    Gosford Central Coast NSW
    Have you changed the fuel supply setup at all?
    In your first page, the engine bay pics look like there is no fuel return hooked up. It also looks like you must have an electric fuel pump, as I couldnt see any fuel lines going to a diaphragm pump on the block?
    With no return, its very hard for the system to regulate fuel pressure properly. The fuel pump and regulator needs to be able to circulate the fuel and the carbie should be tapping off of this circulating supply. All this means is that the fuel should go from the pump to a tee, with one side going to the carb and the other side going to the return to the tank.
    If you get this sorted and check the fuel pressure, it might help it to run right - if the carb is getting too much more or less fuel pressure than about 4psi, it wont work properly.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  9. #29
    Dec 2013
    The exhaust cost just over $400, thats mates rates though.
    When i first bought the car it had a electronic fuel pump without the return. It was giving me some issues so i just went back to the mechanical pump at the front of the engine. Ive read some people saying that a return line is not needed with webers when running the mechanical pump.
  10. #30
    Jan 2006
    You definitely do want to return to the tank with the mechanical fuel pump. I used a restrictor in the return line just at the t-piece leading back to the tank. Also one thing you might want to look at is the internal strainer inside the fuel tank. It is probably all gummed up after all the years of sitting and could be causing fuel starvation. You have to pull the back seat out, undo the little manhole cover, take out the fuel level sender and then get a little hook made out of a coat-hanger or something and pull out the strainer. The gauze is very fine so it blocks up easily.
