Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #91
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by GRN_VAGN View Post
    Thanks jarred, pulls up so well, pedal is soft then all of sudden your head butting the wheel!
    I've had a few passengers nearly faceplant into the dash, good times!
    i like volkswagens
  2. #92
    Sep 2009
    Chillaxing in Tas
    got someone interested in the old engine Josh
    <space for rent>
  3. #93
    Sep 2009
    Chillaxing in Tas
    OM NOM NOM NOM
    <space for rent>
  4. #94
    Jan 2010
    west melbourne
    streeeeetch
  5. #95
    Jun 2007
    yea, nice.
    as steve once showed, these can work very well!
    i like volkswagens
  6. #96
    Sep 2009
    Chillaxing in Tas
    yeah im a sucker for pumped/flared guards and 13's
    Was lucky to find this set, most ive found are basically 0 offset,
    the ones i got are 13x7 rear with roughly + 8
    Fronts are 13x6.5 with +16
    Rear rim just sits inside guard, fronts a little out
    Thanks to Peter For the wheel nuts,
    <space for rent>
  7. #97
    Jan 2010
    Melb Westsideeeee
    That does look pretty darn nice, cant wait to see some tyres on it!!
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  8. #98
    Eastern suburbs of Melb
    Sep 2009
    Chillaxing in Tas
    Thanks mate!
    Todays lesson, You can remove a engine without a hoist, and by your self
    Step 1, jack up front, take wheels off, lower car down with 1 brick under each lower arm. Make sure you got a tyre under engine/box.
    This is a good idea to remove your lower brace if you have one, as i learned its hard to drop a engine with that in the way
    Step 2, undo all mounts, caution, engine may jolt a bit.
    Step 3, jack car up and put wheels on with 2 nuts each, then jack even more up onto car ramps.
    Step 4, slide engine out underneath!!!
    DONE!!......
    <space for rent>
  10. #100
    Aug 2009
    That's actually good to know.
    What ever happened to this car being "low, wide and lumpy"? Haven't seen much of either!
