Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #81
    Mar 2009
    its a noticeable change, it pulls hard and then just dies in power - as if your not accelerating or its chocking. i've got a dellorto side carby.
    any thoughts??
    78 2-door 1.8 KR 16v - twin dellorto's
  2. #82
    Jun 2007
    Eastern Suburbs Melbourne
    I think golfman (josh) had a similar issue. pretty sure he solves it by gettting rid of his velo stacks/trumpets and just running a ramflo filter on it, what filter do you have on atm?
    other problem could be the tuning, either the carb or timing is out of whack
    i like volkswagens
  3. #83
    Sep 2009
    Chillaxing in Tas
    not having too much running issues now...
    Sometimes the temp hits up to 3/4 then backs off. i find its more on the hwy for the first 10-15 mins it will heat up a tad, then back off again. im not worrying about it really.
    As for my carb, it pulls harder the more you rev, right up to 6000-6500.
    But it is rather boggy/laggy/jumpy in first few revs.
    <space for rent>
  4. #84
    Jan 2010
    Melb Westsideeeee
    Hahahaa, i actually like the look of the cable ties running through the duckbill !!!
  5. #85
    Sep 2009
    Chillaxing in Tas
    yeap its different!!
    Thats why i went with white cables
    <space for rent>
  6. #86
    Sep 2009
    Chillaxing in Tas
    So its been a little while, thought id update.
    Thought the brakes where rather crappy on the golf, so decided to upgrade to a rather common setup.
    Vented Rotors up front,
    SEAT Cordoba Rear drums
    SEAT Cordoba Booster with a AUDI Master Cylinder.
    Pulsar Reservoir.
    All went together easy, was done in a couple of hours, alot was cleaning and double checking everything .
    They work rather well, pedal feels soft and then the brakes kick in pretty hard!!.. think ill re bleed them again to see what happens.
    As you can see i have no brake light sensors connected as i think it looks neater without them.... Not to fear, i hooked up a pedal switch curtsy to a Falcon ( XD i think)
    Next step, am sick of the Sloppy gear changes and clunking noises when changing gears.
    So ive Pulled it all out and started to clean it all.. As you can see in pic below the Rubber boots are rather clapped out!! where do i get new ones?
    Also it seems i only have half a bush where the end of the rod connects to steering rack area.....
    Engine is currently stripped and ready to be pulled out in favour for a MK3 golf 1.8L...
    Curious to see how it goes, keeping it all stock, even going to back to a quiet exhaust
    Still got a bit to do, stuff to order but getting there!!!
    <space for rent>
  7. #87
    Jun 2007
    good work with the brake upgrade, you won't know yourself!
    pedal may feel 'softer' cause of the newer/larger booster. its boosts more than the other one, so the pedal will be easier to use. should feel like driving a new car (well the brakes atleast)
    i like volkswagens
  8. #88
    Aug 2009
    You should be able to get a shifter rebuild kit on Ebay. At least the forward most bushings, not sure about the boots further back.
    Good to see an update! Good luck with the swap too.
  9. #89
    Sep 2009
    Chillaxing in Tas
    Yeah getting a full rebuild kit IH8, has links and bushes and the bits to rebuild the shifter ect.
    Thanks jarred, pulls up so well, pedal is soft then all of sudden your head butting the wheel!
    <space for rent>
  10. #90
    Jan 2010
    Baulkham Hills
    hmmm i'd be interested in a similar upgrae.. where'd you get the parts? and wat are you doing with the 1.8L?
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
