Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #71
    Jun 2007
    Eastern Suburbs Melbourne
    I'll look out for it!
    i like volkswagens
  2. #72
    Sep 2009
    Chillaxing in Tas
    look out melbs!!! ill be off the boat around 6am tomorrow haha!! i think im going to get lost :S
    <space for rent>
  3. #73
    Sep 2009
    Chillaxing in Tas
    woo is now in eastern melb, who wants to lend a hand on why it gets so hot?? hahah
    Get some new pics up soon
    <space for rent>
  4. #74
    Jun 2007
    Welcome! can't wait to spot ya! haha
    What suburb you in?
    i like volkswagens
  5. #75
    Sep 2009
    Chillaxing in Tas
    Doncaster East Mate...
    Was a rather scary drive from boat , car was nearly in red on temp gauge and i got a nasty wobble over 80kays
    <space for rent>
  6. #76
    Sep 2009
    Chillaxing in Tas
    So having a problem with hunting idle and stalling lately.
    I checked to make sure idle solenoid was working, and it is. i have also connected it straight to + of coil for a better connection. have yet to drive it like that though as ive just done it.
    Put a New earth wire from carby to tappet cover.
    It just stalls randomly, and if let idle for 30-40 seconds, it starts to "splurge" sort of, idle will drop to around 400rpm, hunt a bit, then even lower to point batery light comes on, then it will jump straight back up to 950-1000rpm.
    Thinking maybe something to do with fuel? How do i go about adjusting float level?
    <space for rent>
  7. #77
    Feb 2010
    kingston, Tasmaina
    what were the tiers on it when you got it mate??
  8. #78
    Sep 2009
    Chillaxing in Tas
    so not much has happened lately
    starter was cranking very slow for a while, backed the timing off, put a new battery terminal and a different starter motor in. seems all good now.
    I also smashed my front spoiler off a few times, it has actually broken the clip in the middle, so i had to zip tie it !!
    <space for rent>
  9. #79
    Mar 2009
    Hey mate I run the same engine/gear box set up as you in a mk1. Just wondering how you went with the engine temp - mine gets to 3/4's almost full and then backs off again like you mentioned - was there a problem in the end of just the way it is???
    Also, when I rev it out, from about 4500 onwards it just dies or misses or something, sort of losing power - just wondering if this is a timing issue or if you had this problem too? I think you mentioned something of it earlier in the thread!...any help would be goood!
    Car looks good too mate, keep it up.
    78 2-door 1.8 KR 16v - twin dellorto's
  10. #80
    Jun 2007
    Quote Originally Posted by dubmc View Post
    ...Also, when I rev it out, from about 4500 onwards it just dies or misses or something, sort of losing power - ...
    is it a noticable change from what it was before 4500rpm, or is it just that it doesn't get any faster after that? what carb are you running?
    i like volkswagens
