Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #61
    Sep 2009
    Chillaxing in Tas
    standard suspension with newish shocks in.
    So much more comfy and nicer to drive. And its good to not see the daughter lifting 6" off seat over every bump
    also got it booked in for a Tune this week. cant wait to drive it once its done
    <space for rent>
  2. #62
    Sep 2009
    Chillaxing in Tas
    Small update
    Picked up a GT40R coil and resistor cheap brand new.
    Fitted it this arvo, turned key and it started.. goodo.
    Just went out now to move car and it wont fire up. being dark i cant fiddle, but everything is connected and nothing is happening.
    Curious to know if having a resistor has dropped the volts too much to make it start when cold?
    Volts gauge is reading just over 12.3v when ignition on. dunno if that helps or not, and drops to around 10ish when cranking.
    Edit, think i got it.
    There a wire runing from fusebox to coil + which has a built in resistor, and ive gone and added a external resistor. so this would lower the voltage again yes?
    If so is the GT40R suited?
    Going to borrow a multimeter and do some testing tomorrow
    <space for rent>
  3. #63
    Sep 2009
    Chillaxing in Tas
    Disconnected Ballast resistor as i found the wire built into loom that is resisted anyway.
    Car starts now
    Fitted New Water Temp gauge and re did wiring to the amp and oil pressure gauges.
    Tidy up interior and neaten wiring up under dash so its no hanging around.
    Couple of pics
    Dont mind messy engine bay, still got to fit new Fuel hoses, and tidy up some others.
    <space for rent>
  4. #64
    Sep 2009
    Chillaxing in Tas
    anyone know where i can get some of these?
    Found some rims i like, but i need something like them to fit em
    <space for rent>
  5. #65
    Jan 2010
    Baulkham Hills
    i think you should let me have your old wheels when you move on
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
  6. #66
    Jun 2006
    Orange NSW
    A wheel/tyre shop perhaps?
  7. #67
    Sep 2009
    Chillaxing in Tas
    i dont even know what they called :S
    Cant just walk in asking for a "wheel bolt long thingy that goes in rim sorta thing"
    And which ones josh? the 15's? thats what i got on it atm
    <space for rent>
  8. #68
    Jan 2010
    Baulkham Hills
    hmmm dunno.. hahaha i'm actually just so lost when it comes to wheels...
    oh we gonna try and catch up on wednesday>??
  9. #69
    Jun 2007
    Eastern Suburbs Melbourne
    Looks much better now that you've neatened it all up!
    i like volkswagens
  10. #70
    Sep 2009
    Chillaxing in Tas
    Cheers mate
    You might see it driving around eastern melb in 2 weeks
    <space for rent>
