Got Coil now
Didnt have GT40 so got a a Champion CIC31 coil, which is internal resisted same as the GT40
Will put it on tomorrow
<space for rent>
Got coil in, now car wont start, any ideas?
I put the wires on same spots and nothing
EDIT, turns out the coil is faulty, i tried every which way and different leads. nothing
Tried same combos with old coil and it started every time. Hmmm
<space for rent>
Had the same thing happen on an air cooled with a Bosch Blue coil ,put the old crusty one back on and its still going strong must be 40+ years old now
Yeah pain in the arse majour!!
Off to take it back tomorrow maybe, and get them to order in a GT40, fingers crossed that works
<space for rent>
Hmmmm
<space for rent>
Well have since added a new dizzy cap, rotor button and some nice new spark leads
Got a stock Coil on for now till my GT40 gets here.
Runs well. Still cant fix the Oil leak fron tappet gasket though, any idea's? Its a brand new rubber one, all one piece. Seems to leak from near the cam wheel and runs down back of block. Ive tried refitting gasket 3 times, and i cant get it right,. On a cork gasket it has the separate Orange rubber bit near cam wheel, the one piece gasket doesn't fit in that groove too well.. .
Not much more now, coil, oil leak, gear box oil leak
And exhaust.
<space for rent>
i've never had issue with a one piece rubber gasket. Check the rocker cover, maybe it's slightly damaged or out of shape? Also, did you install new studs at the same time??
The other option would be to go back to a cork one, and apply some sealant to stop the leaks.
Just paid a pretty penny for a rubber one, not going back to cork
Cover looks ok, going to try some sealant and see what happens. and yes i changed studs
<space for rent>
- You may not post replies
- You may not edit your posts
Forum Rules
