Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #41
    Mar 2006
    brisbane
    you could just carefully use thinners to clean the excess undercoat from outside of the flares..
  2. #42
    Sep 2009
    Chillaxing in Tas
    Or just replace the guards with dark blue rust free ones like i have just done
    On a side note, had a electric Dizzy setup with proper coil and everything. dizzy was rooted so i went back to Points Dizzy but kept the Electric igntion coil. will i need a Ballist resistor?
    Might have asked before, but i should have golf done by weekend so want to know so i can get one when i buying other stuff
    <space for rent>
  3. #43
    Gosford Central Coast NSW
    you do need a ballast resistor if your running points.... unfortunately you'll have to fit one cos the diesel downt have the ballast resistor already
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #44
    Sep 2009
    Chillaxing in Tas
    Ahk thanks mate, how does it hook up?
    <space for rent>
  5. #45
    Boronia VIC
    Quote Originally Posted by GRN_VAGN View Post
    It depends on the coil you're using. If you use one out of a petrol golf, then yes, you will need the resistor. The petrol Golfs have a resistive wire in the loom rather than a discrete ceramic resistor.
    If you're using an after market coil you can select one that doesn't need a resistor.
    For example the Popular Bosch GT40 coils are available for use with (GT40R) or without (GT40) a resistor.
    I use GT40 coils in 3 of my cars with no resistor. The cars were all originally diesels.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  6. #46
    Sep 2009
    Chillaxing in Tas
    The coil is a VW/AUDI option for electric ignitions, and from what i read they dont require a resistor when running electric or points dizzy as they are internal resisted?
    The golf is a diesel converted to petrol, and it did have a external white resisitor but i ditched it when i converted the igntion (which was faulty )
    <space for rent>
  7. #47
    Perth. WA
    You dont want to use the electronic coil for a points type dizzy, it will weld the points in no time at all, do as Pete has suggested and use a bosch GT40 set up.
    The electronic dizzy coils are for user with the TCI and hall effect distributors.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  8. #48
    Sep 2009
    Chillaxing in Tas
    Ahhk awesome, so a GT40R is what ill need then?
    Might grab one in couple of days, cheers
    Picked up a new water pump to fit soon, got some new points to add in when i get coil. Tried my Chrome bumpers on it, looks funny!! black bumpers all the way for it
    Also Temp and fuel gauge stopped working when i pulled cluster out. checked fuse, and all the wiring looks good. any idea's? what to look for?
    <space for rent>
  9. #49
    Boronia VIC
    Nope a plain GT40 is what you're after. (No resistor required.)
    GT40R is to be run WITH a resistor.
    Pete
    7? MK1 Caddy
    12 Amarok
  10. #50
    Sep 2009
    Chillaxing in Tas
    Ahh yeah, i get ya
    <space for rent>
