Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #31
    Sep 2009
    Chillaxing in Tas
    Yeah im eventually going to put all new temp gauges in to match my current Speco ones.
    And yeah my corolla had crap under cap for first 2 weeks of driving it after a freshen up. went away and hasnt been back. i know its worse during winter here in tassy, condesation in engine.
    ill give it a couple of weeks, but water in bottle was clean, no bubbles or gunk,
    And good to know about the pressure, im just paranoid haha, everytime it made a noise today i was like "****, what was that?",
    <space for rent>
  2. #32
    Sep 2009
    Chillaxing in Tas
    Switch pumped from electric to Mechanical, that fixed like 4 problems but found like 3 more haha.
    so went to set float level, one of the floats had broken off. so i Soldered it back on and set level.
    set mixture
    and this is the end product (you can hear a slight whine, think the bearing in the tensioner has got noisey
    http://www.youtube.com/watch?v=13tD4F7OMW4
    <space for rent>
  3. #33
    Sep 2009
    Chillaxing in Tas
    So
    have racked up 70kays on the Golfy since new engine in.
    Its quick, would be quicker if i could open up second side of weber without it hesistating.
    Also im a bit sick of the Cam in it. it doesnt like me to cruise, and actually uses a fair bit of fuel when "off cam". on cam its nuts, will rev clean off the tacho and will easy pull over 95kays in 2nd.
    Going to pull cam out and put the other one back in, hoping i dont loose much power, and hope i get alot more go in lower revs and not have to rev the snot out of it .
    <space for rent>
  4. #34
    Boronia VIC
    Quote Originally Posted by GRN_VAGN View Post
    Its quick, would be quicker if i could open up second side of weber without it hesistating. .
    Try blocking off vacuum to the dizzy it might need a mech only advance dizzy setup.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  5. #35
    Sep 2009
    Chillaxing in Tas
    Ahhk, i will try that tomorrow.
    I got two vacuum lines coming off dizzy, block them both?
    <space for rent>
  6. #36
    Sep 2009
    Chillaxing in Tas
    So she off the road still, carby problems. hunting down a replacement carby now
    Have tidied it up more, hide some wiring under hood and added that plastic wrap stuff.
    Also fitted rear swaybar correctly.
    And freshened up the twin headlight grill
    <space for rent>
  7. #37
    Aug 2006
    Melbourne VIC
    Very rad looking dog!
  8. #38
    Sep 2009
    Chillaxing in Tas
    Hahha yes he is... that would be my Daughters Dog "Choppa" lol
    <space for rent>
  9. #39
    Gosford Central Coast NSW
    Car looks tough mate
    Next to paint under the arch mouldings.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  10. #40
    Sep 2009
    Chillaxing in Tas
    yeah im going to, going to see if i can get a spraycan mixed up to neary match the same green. dont plan on repainting the whole car any time soon, so will do for now. and most of it is covered by the flares anyway
    <space for rent>
