Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 103
Thread: My Mk1, Low Wide and Lumpy
  1. #21
    Sep 2009
    Chillaxing in Tas
    i do get this place
    1) i rely on this car daily, so i cant risk a defect with the superlites on. do you realise how far they poke out?
    2)its about 10mm higher, but our roads aint the best, so that extra 10mm will be nice
    And yes the engine is a ripper, drove it in the donor car i pulled it out of and man did it fly
    <space for rent>
  2. #22
    Aug 2009
    Torquay, victoria
    u still selling the superlites or are they gone?
  3. #23
    Sep 2009
    Chillaxing in Tas
    Gone.
    Sorta regret it a bit, but i was never going to run them
    <space for rent>
  4. #24
    Quote Originally Posted by GRN_VAGN View Post
    i do get this place
    hahah, just thought i'd give you a stir. keep on keeping on.
  5. #25
    Sep 2009
    Chillaxing in Tas
    no worries
    well got engine in today, then gearbox decided to be an arse and not let me select 4th ... and before ya all ask, yes the links where right, and i couldnt select 4th by hand on the box
    Anyway, motor out, and new box going in tomorrow.
    <space for rent>
  6. #26
    Sep 2009
    Chillaxing in Tas
    pic time
    <space for rent>
  7. #27
    Feb 2008
    Melbourne.
    looking good Dan...glad to see more Mk 1 owners with baby strollers on their front porch too !!
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
  8. #28
    Sep 2009
    Chillaxing in Tas
    Cheers Mark
    Yeah the Little loves the Mk1
    she turns 1 next month actually ... every time we go for a drive in it she cant stop making car noises haha
    <space for rent>
  9. #29
    Sep 2009
    Chillaxing in Tas
    so she is back up and running again.
    few Q's (yes im paranoid lol)
    1)Whats oil pressure roughly supposed to be? mine goes up to neat 65psi when i hit the loud pedal, and will sit at 40psi when im in 4th at 50kays.
    2) Gauge says its hot (3/4 on gauge) fan kicks in and then drops, heats up more at idle. but water doesnt feel that hot, hot enough to not be able to hold finger in for like 3-4 seconds lol.
    3) Was a slight trace of some milky **** under cap, and a little around lip under valve cover. Should i be worried? engine has been sitting for over 12months prior ro me starting it today. Ive changed cam, clucth, flywheel, some gaskets, oil and filter, ect ect.
    4)What cause the timing to "bounce" ? timing mark looks perfect with timing light, then all of a sudden the mark jumps to the left about 10mm for a few flashs and then goes back :S
    Anyway, will tinker tomorrow and see what i can do
    <space for rent>
  10. #30
    Jun 2006
    Orange NSW
    1- Oil Pressure sounds OK. It will go up (to a point) when the revs come up..
    2- Gauge or temp sender might be faulty.. Maybe dirty connection? If it was too hot you'd know about it when you stuck your finger in the coolant!
    3- If your water goes murky, or your oil, you're in trouble. If it's a bit of crap under the cap, i wouldn't be too concerned. You may also get condensation under the oil filler cap the first couple of times you start it if it has been sitting around. Don't be too concerned (unless it doesn't go away).
