Results 1 to 9 of 9
Thread: My MK1 GTI 1980 Euro spec Turbo Technics
    Nov 2007
    Adelaide (At last!)
    Hi all,
    Thought it was time to post some pictures of my MK1 GTI up for you to see. I have owned him for 22 years now and imported him 7 and a half years ago when we emigrated (also bought my Corrado VR6 Storm with me, see Corrado forum for piccies).
    The Golf is modified as you can see, but I have tried to keep it looking pretty stock on the outside, and yes it was a nightmare getting through Regency Park here in SA. Had to get an engineers report, fit side intrusion bars, child seat anchor points and removed the Forge atmospheric dump valve.
    The mods done were all by myself except the fabrication of the inlet systems andd the exhaust system. This and the mapping for the emerald ECU was done by JKM Motors in Portsmouth UK (great guys!).
    Here is what has been done.
    280mm Corrado G60 front rotors, MK2 Golf Disc Brake rear conversion (uses 16V MK1 Scirocco handbrake cables), MK2 Golf brake servo and M/cylinder.
    EV 1800 Solid lifter engine from MK2 Golff GTI, Bored and stroked to 2Litres with Cosworth Forged Pistons.
    EIP Solid head gasket to lower compression to 9:1
    Scat baffled trapdoor sump, 16V flywheel and Helix organic clutch.
    Turbo Technics T3 cast manifold with Garrett T3 Turbo.
    16V oil pump for DIS igntion (no distributor).
    Custom fabricated inlet system and intercooler based on TT design.
    Corrado G60 Green Top injectors mounted on modified inlet ports and a reversed MK2 GTI Fuel Rail
    Emerald Engine Management system, MAP based, DIS Coil Pack ignition, custom HT leads, Mapped Boost, Trigger wheel timing.
    ECU Sensors for Air inlet temp, Coolant temp, Boost (2 Bar Cosworth Sierra sensor), Inductive trigger wheel timing sensor, TPS modified from Passat.
    ECU Driven Coil pack ignition, N75 boost modulation valve, injection timing.
    3 Maps selectable from interior: Hi Boost, Medium Boost, Low Boost for poor fuel.
    Boost controlled fuel pressure regulator.
    Narrow band Lambda sensor and gauge in car.
    Custom fabricated SS exhaust system with ceramic coated downpipe.
    MK2 Scirocco ACD code gearbox (same intermediates but higher final drive),Peloquin ATB Differential (Automatic Torque Biasing), Scirocco drive shafts.
    TSW Alloys with Yokohama 195/50-15 tyres.
    Eibach upper front stress bar, custom fabricated lower stress bar.
    Eiback anti roll bars and springs, Koni top adjustable Shocks
    The car was set up on a Dyno Dynamics rolling road and this took about a week to map.
    The car made 150kw but we detuned it to 130kw to avoid detonation here in Australia with elevated temps and lower grade fuel availability. It makes 271 Newton Meters of torque.
    Boost is limited to 8PSI.
    The torque curve is beautiful and the car drives very strongly off boost.
    Hope you all like it and any questions, just give me a shout.
    Attached Thumbnails Attached Thumbnails My MK1 GTI 1980 Euro spec Turbo Technics-dscf1928-jpg   My MK1 GTI 1980 Euro spec Turbo Technics-dscf1929-jpg
    My MK1 GTI 1980 Euro spec Turbo Technics-dscf1920-jpg   My MK1 GTI 1980 Euro spec Turbo Technics-dscf1926-jpg
    My MK1 GTI 1980 Euro spec Turbo Technics-dscf1925-jpg   My MK1 GTI 1980 Euro spec Turbo Technics-dscf1924-jpg
    My MK1 GTI 1980 Euro spec Turbo Technics-dscf1923-jpg   My MK1 GTI 1980 Euro spec Turbo Technics-dscf1922-jpg
    My MK1 GTI 1980 Euro spec Turbo Technics-dscf1919-jpg   My MK1 GTI 1980 Euro spec Turbo Technics-dscf1921-jpg
    My MK1 GTI 1980 Euro spec Turbo Technics-dscf1948-jpg   My MK1 GTI 1980 Euro spec Turbo Technics-dscf1927-jpg
    Sounds like a nice sensible setup without going over the top. You must be getting old.
    The intake plumbing on top of the engine only has short pieces of flexible pipe at each end. Are there any problems with stressing this pipe as the engine rocks back and forth?
    Use it much?
    Paul
    Nov 2007
    Adelaide (At last!)
    Hey mate, ha ha, well I aint getting any younger!
    The Viper silicone piping is very flexible and has not been a problem with the pipework. This is just like the Turbo Technics original. I dont use it as much as I should, but have vowed to get out in it more often.
    Yes the power figures are sensible for an old school motor and really any more than that would be hard to manage without detonation. As they weight about 800kg, its all about power to weight as you know
    Feb 2009
    Please Enter Location
    Lovely motor you have there,much respect.
    Nov 2007
    Adelaide (At last!)
    Thanks man
    Nov 2014
    Good looking car
    Nov 2007
    Adelaide (At last!)
    Quote Originally Posted by Notso Swift View Post
    Good looking car
    Cheers buddy
    Corrado VR6 Storm
    Nov 2007
    Perth
    Nov 2007
    Adelaide (At last!)
    Quote Originally Posted by tinto View Post
    Wow!
    Very cool machine.
    Thanks mate
    Corrado VR6 Storm
