Crusader Motors - Hawthorn
Car needs:
RH & LH stop light globes faded
Windscreen Squirter motor n/w
LH front seat belt not retracting
Inside boot side panels re-secure [due to electrical wiring]
Rocker Cover gasket [leaking oil]
Engine sump gasket [leaking oil]
New oil filter [leaking oil]
Oil pump seal [leaking oil] re-co pump
5 liters of engine oil
Welsh plugs [leaking water]
4 liters of 100% concentrated coolant
Rack ‘n’ pinion [has excessive free-play on RH side] re-co rack
2liters of power steering oil
Front brake pads are very low
LH & RH disc rotors machine [glazed and grooved]
LH & RH rear wheel cylinders [leaking oil]
2x 500mls brake fluid- bleed all brakes
2 liters of cleaning fluids
4x tyres [205/45zr16 fitted to the vehicle are too wide, rubbing on the chassis and under minimum
clearance between shock absorbers] 195/45zr16 recommended
4x wheel balance
4x wheel computer alignment
"It is hard to determine exact cost involved for the listed repairs and you can see there is decent amount of work involved, an approximate price range is $4000-$5000. The reason for a $1000 bracket is due to some parts that may be required however cannot be identified untill the work coimmences and only when its its process. As well as the labour involved can vary and can only be accounted close to completion of the work. "
The Workshop - Hawthorn
"Steering rack price is $825 fitted. This is if your own steering rack is overhaul able, if not we have to try find a second hand unit that is. According to our steering specialist they have a tendency of rusting internally which makes them useless and have to be thrown away. We are not sure what a second-hand unit is worth, apparently we’ll cross that bridge if we need to, however it will be a cost on top of the $825
As for the other work required from the report I’ve estimated it at approximately $970. This includes left high beam light, new rocker cover gasket, steam clean engine, wheel alignment, reset rear muffler, locate/make bushes for gear selector,
Rectify right front wheel guard hitting tyre.
All the above mentioned prices are inclusive of GST, parts, labour and oils. As with all quotes please remember they are only a guide and do not allow for the unseen."
As you can see, pretty huge difference between the inspection reports (they barely converge but for the steering!)
I'm pretty inspired by the MK1 passion here so I'm gonna follow your guys lead and try and do some stuff myself. But... Where to start
