Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
Thread: My '91 MK1 Golf Cabby
    Aug 2006
    Melbourne VIC
    Go to Volkscare in Boronia.
    He is honest and wont rip you off!
    Oct 2014
    Melbourne, Victoria
    Quote Originally Posted by Big Yellow View Post
    which workshops have quoted you out of interest??
    Crusader Motors - Hawthorn
    Car needs:
    RH & LH stop light globes faded
    Windscreen Squirter motor n/w
    LH front seat belt not retracting
    Inside boot side panels re-secure [due to electrical wiring]
    Rocker Cover gasket [leaking oil]
    Engine sump gasket [leaking oil]
    New oil filter [leaking oil]
    Oil pump seal [leaking oil] re-co pump
    5 liters of engine oil
    Welsh plugs [leaking water]
    4 liters of 100% concentrated coolant
    Rack ‘n’ pinion [has excessive free-play on RH side] re-co rack
    2liters of power steering oil
    Front brake pads are very low
    LH & RH disc rotors machine [glazed and grooved]
    LH & RH rear wheel cylinders [leaking oil]
    2x 500mls brake fluid- bleed all brakes
    2 liters of cleaning fluids
    4x tyres [205/45zr16 fitted to the vehicle are too wide, rubbing on the chassis and under minimum
    clearance between shock absorbers] 195/45zr16 recommended
    4x wheel balance
    4x wheel computer alignment
    "It is hard to determine exact cost involved for the listed repairs and you can see there is decent amount of work involved, an approximate price range is $4000-$5000. The reason for a $1000 bracket is due to some parts that may be required however cannot be identified untill the work coimmences and only when its its process. As well as the labour involved can vary and can only be accounted close to completion of the work. "
    The Workshop - Hawthorn
    "Steering rack price is $825 fitted. This is if your own steering rack is overhaul able, if not we have to try find a second hand unit that is. According to our steering specialist they have a tendency of rusting internally which makes them useless and have to be thrown away. We are not sure what a second-hand unit is worth, apparently we’ll cross that bridge if we need to, however it will be a cost on top of the $825
    As for the other work required from the report I’ve estimated it at approximately $970. This includes left high beam light, new rocker cover gasket, steam clean engine, wheel alignment, reset rear muffler, locate/make bushes for gear selector,
    Rectify right front wheel guard hitting tyre.
    All the above mentioned prices are inclusive of GST, parts, labour and oils. As with all quotes please remember they are only a guide and do not allow for the unseen."
    Quote Originally Posted by Mk1@4Motion View Post
    Hey bud, try doing these jobs yourself. It'll teach you about the car and also how to work on them a little bit. Its all part of the fun.
    All of that's easy accomplished on a lazy Saturday afternoon by someone who knows Golfs.
    Maybe a $200 tops to sort that lot out if you do it yourself with some advice form the brains trust on here.
    Steering rack issues could also be due to a broken mount and might require a little welding. Nothing major.
    If a steering rack mount is broken it also affects the gearshift as one of the levers mount off the rack.
    Nice looking Car!
    As you can see, pretty huge difference between the inspection reports (they barely converge but for the steering!)
    I'm pretty inspired by the MK1 passion here so I'm gonna follow your guys lead and try and do some stuff myself. But... Where to start
    Quote Originally Posted by tafe View Post
    That's not the symptom of a faulty rack otherwise there would be movement on both ends. Sounds more like inner tie rod end - less than $100 to fix.
    Start with whatever you're comfortable with and ask for advice as you go.
    16" wheels are a bit too big for a MK1, 15s suit much better but I'm biased - I'm looking at upgrading my 15's to 16's on my MK2 if ever you want to swap.
    Paul
    Feb 2013
    Melbourne SE
    Quote Originally Posted by Water Boy View Post
    +1
    Boris at Volkscare is a legend. I got my roady done by him and vicroads regoed it the same day! Cost me 220 with a very similar looking list. I did do almost everything myself though haha. Just listen and learn and you'll save yourself a bunch from dodgy mechanics
    Oct 2013
    ACT
    Car needs:
    4x wheel balance
    You start on what you feel is easy enough for you so that you get the hang of it and progress to the more harder stuff until all is done. And I am pretty sure once you start and you have questions you can post them on here and there is plenty of guys with an abundance of knowledge who can walk you through it step by step.
    Only The Good Die Young 45
    For a better ride, go WIDE!!!
    VS Commodore V6 Berlina- FOR SALE
    1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
    May 2011
    Albury, NSW
    Hold on - they're charging you for power steering oil - do you have retro-fitted power steering? Because no MK1s came with it! Lol - definitely a rip off!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Boronia VIC
    Very little goes wrong with the steering racks internally. I'd be very surprised if there was anything wrong with it. There plenty of '76 golf's still running their original racks 500,000km later. Most likely broken mount or worn tie rod end.
    Sometimes an internal bush wears out but it's easy to press a delrin bush in without removing the rack. This only usually happens to us crazy motor sport types though. Rally and circuit racing is tough on the racks.
    The comment about the oil pump seal is very odd. There's no such thing in a golf motor. The pump is in the sump. Might be that he means the filter housing gasket but I'd be concerned by this amount of ignorance. Nobody would ever reco an oil pump either they're only worth about $80 trade.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Perth. WA
    Quote Originally Posted by nightphotographer View Post
    Not true. RHD models came without power steering, LHD later models ( cabriolets ) did infact have power steering. Unfortunately the LHD PS rack is not interchangeable with RH cars.
    Tim Styles in UK did put together a PS retrofit kit for Mk1's years ago, would be suprised if any came to Oz tho.
    A local guy here in Perth retrofitted a PS rack from a jap car that was almost a bolt in job for his autokhana Mk1 .
    Then again, what did the late South African built golfs optioned with ??? anyone know ??
    As fot the OP, welcome to the Mk1 club, where simplicity reigns learn about your car and have fun man.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Oct 2013
    ACT
    Quote Originally Posted by roccodingo View Post
    From memory if I am correct the later model Mk1's which was built until a few years ago did come with PS but also only on request. Worth giving it a shot to see if those racks are worth importing and fitting one yourself.might fit.
    May 2011
    Albury, NSW
    That's what I meant - no RHD models.
    Crazy Quiffs do a ludicriously expensive conversion kit - Items - there's another kit too that my Hayne's mk1 restoration manual mentions - maybe that's the one you're talking about.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
