Pix please.
Will there be an issue with the flywheel not being balanced with the crank?
Paul
Wow, I think it's actually been 9 months since I was in here last, holy crap time flies.
The car has been completely gutted, the entire steering/suspension/brakes have been completely rebuilt, not a single nut or bolt hasn't been touched. It's a happy roller now, and with the 020 5 speed just being finished with its rebuild this week I'm looking to finally have a full drivetrain back in the car. Also found more rust in it after paint but nothing exterior so you can't tell we had to repair it after all the paint kafuffel.
I do have a question for all you old schoolers. The flywheel I gained with the 020 has fairly large cracks in it, and has been condemned. Is it a viable solution to run a 210mm flywheel and clutch kit on my 1.6L? Apparently it's fine but anyone with experience in this willing to share would be greatly appreciated!
'77 Golf mk1 GLS - ground up resto - Sold
'97 Golf mk3 GL Wolfsburg Edition - JOMs, daily driver - Sold
MY17 Golf GTI 40 Years Edition - DSG
2010 GSX-R 750 - Daily rider
Pix please.
Paul
Geoff Hale is running a 210mm flywheel on a 1600 in his rally car. Ping him a PM.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
You wont have any issues with the flywheel. I have run 210mm setups in all my previous mk1's. You should be able to bolt up any old mk3 era flywheel/clutch/pressure plate assembly, as long as you have the right input shaft splines for your gearbox.... there are 2 types, big (mk2 16V and one of the mk3 era 2.0L 8V) and standard. Its a good idea to check your flywheels TDC marking while you are assembling everything to make sure you have a good reference for later, although in my experience, they always match up (I have heard stories to the contrary, but I have never found this myself).
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
So, I find myself in need of serious assistance.
I have sorted all the engine/gearbox dramas, its all bolted together on my garage floor, awaiting the engine mount to arrive from overseas.
Trouble is, I have ordered the mount insert twice, the first time I received the 74mm diameter one, the second and most recent I got yesterday is the 64mm one. I'm really struggling to understand how difficult it is for someone to send me the correct mount insert, both times I have asked for the 60.4mm one as removed from the car originally. I am aware this mount size is usually from a 1.1 or 1.3l, however as its what came out of the car it's what I have to work with.
I have checked all the part suppliers I can think of, all the ones I have previously used for parts, I googled it and can only find one supplier, however they say a "minimum" 6 weeks until its in stock, then another 2 weeks delivery. Not sure I can wait that long.
Does anyone know how I can get this mount insert quicker/locally, or does anyone have a mount that suits the 64mm insert they would like to part with for cash????
Let me know if you can't find anything close by. My local wrecker has dozens of MK1's rusting away on his property so there's bound to be something suitable.
Paul
