Results 1 to 10 of 11
Thread: more problems
    May 2006
    Maryborough Vic
    Angry more problems
    fixing carby today and looked down and found this
    is this a common problem
    i drive it pretty hard
    i like noise too
    its nice and deep for a 1.6
    it blows a bit of smoke
    but i do drive it hard and very short trips
    Sep 2006
    Parkinson / Brisbane
    damb . . . . will that be an engine out job?!
    May 2006
    Maryborough Vic
    Question
    might see if i can jack it and mig it
    i hope
    just will drive it nice for now
    its my work car
    Camden, Sydney
    Didn`t you have a solid bush in there???
    This is your punishment.
    Never seen a mount crack like that, but I`d probably weld it where it is.
    May 2006
    Maryborough Vic
    the old mount was hard
    but there wasn't any cracks when
    i put the new standard one in 6 months ago
    engine moves alot on take offs
    exhaust bangs on the floor and it has to move 3 to 4 inches to do that
    Gosford Central Coast NSW
    it shouldnt move that much - the radiator support engine mount and the rear gearbox mount should prevent that movement if adjusted properly.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Camden, Sydney
    Yeah one of the mounts must be rooted for it to hit the floor. Front mt or rear gearbox one probably.
    Apr 2006
    Hobart,Tas
    They move heaps when the bracket breaks off. I have welded a few back on with the motor still in.
    Canberra - We make the Rules
    my engine mount failed the other day - the same one. The rubber wore out, and now i have a massive vibration making the whole car shudder.
    how do i go about replacing that same mount as the one pictured above??
    spanks
    Und keine Eier!
    76' 3dr - GTI (well it looks like one, OK??)
    May 2006
    Maryborough Vic
    was a bit slow at work today so i put it up
    on a hoist all the engine mounts are intact
    front one under the radiator was a bit off line but ok
    a hammer fixed it
    these add to the problem
    bridgestone potenza g111's 205/60/13
    unreal grip and handling
    4 grand drop the clutch and your launched
