Page 27 of 37 FirstFirst ... 172526272829 ... LastLast
Results 261 to 270 of 368
Thread: mk1lyf
  1. #261
    Sep 2012
    Noooouuice !
    Its the little things..
  2. #262
    Jan 2012
    St Albans, Victoria
    Awesome. Looks like we need to attend some hill climbs
  3. #263
    Nov 2010
    Melbourne - SE
    also, i'm currently running a 1.8 (RV) engine with the standard mk1 4 speed box - if anyone can shed some light on which clutch I should be getting (1.8 RV runs a 210mm clutch whereas the 4speed box originally had a 190mm clutch) would be greatly appreciated!
  4. #264
    Nov 2010
    Melbourne - SE
    and yes a 5 speed conversion is hopefully happening very soon!
  5. #265
    Feb 2013
    Melbourne SE
    From what I understand, all 020s use the same bell housing casting, so you just have to match the clutch to the flywheel. Although don't just take my word for it. My car is running a 1.8 adz, which usually have a 210mm clutch, with a mk1 4 speed, but I don't know what size clutch it has in it at the moment.
  6. #266
    Nov 2010
    Melbourne - SE
    also it might just be me but the mk6/7 forums seem to be an absolute joke and I just had to share that
  7. #267
    Feb 2013
    Melbourne SE
    You could always search the part number printed on the flywheel if you can be bothered separating the gearbox from the motor
  8. #268
    Nov 2010
    Melbourne - SE
    Quote Originally Posted by Browneye View Post
    Makes sense actually! Thanks dude!
  9. #269
    Feb 2013
    sydney
    Lucky you found them Elton
  10. #270
    Feb 2006
    Melborune, VIC
    Just match your clutch disc, pressure plate, flywheel to the gearbox you have. That's the easiest as they all bolt to the standard 4 cylinder crank.
    There are heaps of variations on what you can/can't use, but save that discussion for the 5 speed conversion.
