welcome indi,
just upload your photos to a third party like www.photobucket.com and then post the url link,,,much easier!!!
any problems ,look in here!
http://www.vwwatercooled.org.au/newf...ead.php?t=3532
Hi all, just thought I would share some pics of my new girl but I cant get the pictures small enough. Can some one tell me now you get a Jpeg down to 19KB?.
Anyway she's a lovely white Cabriolet that I picked up on Sunday.
Here's the list of to do's
Re-attach rear vision mirror
Find out why there is a screw driver holding the drivers seat in place?
Find out why trip meter says Sydney to Newcastle is only 40klm?.
Find out why there is so much oil over the motor
Find out why 3rd is easier to find than first
Find out why it smells like a ferret when the lids down
Find out how to top up the power hood oil
Find out why the brakes are so spongy
Find out why the rear wheel screams like a banshee
Find out why the brake light keeps flashing on and off.
I'm having so much fun and I havent even started to pull her apart yet, bring on the weekend.
Love the Forums look forward to sharing some great experiences.
OK lets see if this works the links to the pics are
welcome indi,
Welcome to VWwA Indi
You not Indiana Jones by any chance ?![]()
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
I think your car must be a Cabrio Mk1 not a Mk2 if you have a hydraulic hood.
Show us a pic.
Welcome to the forum.
Looks Tidy. Nice car for summer.
We can help you wiith all those problems.
Stick around, this is a useful place.
welcome mate
congrats on the purchase, beaut little car, most if not all your questions will be answered here, plenty of knowledge floating around!
I didnt think VW made a MK2 Cabrio?
Either way, Welcome to our humble community.
Love the Mk1 Cab's we have quite a few members with them.
(probably need new nylon shims in the tracks)
(the barrels are slipping on their axle. Take the speedo to VDO. About $80)
(Could be as simple as the seal under the filler cap - try a new cap)
(Probably a linkage issue, the kits are not expensive. Brian at GTI probably has them as well as good advice 0296531114)
(You maybe got a ferret in the works)
(Its a generic Mk 1 design feature. As well it could be related to your flashing light. Check the fluid level fast)
(Wheel bearing?)
(The light has two signal functions: low fluid level, no pad depth)
Looks like its gone to good hands.
Pretty car.
I had a full day working on the Cab yesterday, this is the progress. (thanks for everyones help)
((The Spike that normally takes the place of the screwdriver was found under the seat, The tube/Guide that it sits in has been completly snapped off. It will require me doing a bit of mild spot welding, Nylon seat guides also shot))
(( took the speedo out it sound like a maraca, will have to go to VDO))
((the other culprit, The oil sender switch))
((replaced a missing bush, all the other bushes seem ok, gear stick travel is a lot better but still hard to find 1st, Golf Loon thinks it may be the linkage needs adjustment))
(( Got the pressure washer out, the result had a resemblence to Stout/Guiness or Tooheys Old, Previous owner was obviously a dog/ferret lover))
(( looks like there is a bolt on top of the drive unit, may be able to fill it via a squirt bottle filled with clutch fluid, Has anyone had to fill these units before?))
((Fluid level was fine, rear shoes have about a Mil left on them, talking to Golf Loon about some options)
(Wheel bearing?)
((rear brake shoe is scrapping))
((think its because of the 2nd one))
Pretty car.
Thanks, with a bit of work and some help I think it will come up a treat.
I'm very impressed with how well they go, eats the `79 Porsche 924 I use to have.
I thought some Cab owners may have warned me about cruising with the top down, My receding forehead glows brighter than my brake warning light now!!!!!
