mk1 - 4x 100 pcd, not sure what centre bore is (57mm?), offset 35-38mm; any larger you'll probably not clear your brakes, any larger and you'll rub your guards unless you roll'em ;
mk3 4 stud wheels should fit - any mk1's/ 2's out there that can elaborate?
this is common with japanese 4x100's but not all japanese wheels will have big enough centre bore.
see here:
http://vwwatercooled.org.au/vwforum/viewtopic.php?t=288
