Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: mk1 rear disc conversion
  1. #31
    Perth. WA
    Simon, I would just buy new ones mate as used ones tend to be full of crud from brake fluid not being changed regularly enough. I can sell you a couple used ones but frankly there really bin material when it comes to braking safety.
    Classic Parts Center
    folow this input :-Sie sind hier: / Scirocco / Corrado / Scirocco II / Fahrwerk / Bremsen
    124.66 Euro each..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  2. #32
    Dec 2009
    Fitzroy, VIC
    Thanks mate, I'm thinking I'll source new or aftermarket adjustables...
    Looking at aftermarket adjustables from Wilwood and other brands, none seem to be adjustable to reduce brake pressure by anything more than 57% - Brake Proportioning Valves - SummitRacing.com
    Apparently this won't be enough as per this thread on vortex: VWVortex.com - Wilwood Porportioning Valve Question
    So looks like OEM is the only way to go.. surely this can't be right, what about racing applications!?
  3. #33
    Boronia VIC
    They're also still available from Lotus.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  4. #34
    Dec 2009
    Fitzroy, VIC
    Awesome, thanks Pete.
    Managed to find them for sale for $105.48 USD each x 2 = $250AUD incl. postage
    https://www.busdepot.com/brakes/533612151a
    Order placed...
    EDIT: Gutted, got an email back from them saying the part is obsolete .. i.e. from Classic Parts Center only
  5. #35
    Apr 2006
    Melbourne, Victoria
    VW Golf GTI G60 VR6 Turbo Druckminderer Bremsdruckregler 3/15 | eBay
    I think they're ATE part no. 24.6043-1701.3 (a Pug part with the same characteristics) however adapters are required to mate it up to the VW brake lines
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
  6. #36
    Aug 2011
    Canberra
    Hmmm, not too sure how useful this is to us, but the Lotus guys have been rebuilding 3/35 units to be 3/15 units by changing the spring.
    Lotus Elan Central • View topic - GM Proportioning Valves investigation for compatibility
    Has anyone checked the spring in a 3/15 unit and compared it to a 3/35 spring?
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  7. #37
    Perth. WA
    yes, and the only difference is the spring. Looked at getting one of the local spring makers to do me a run of springs for this about 6 years ago, cant find the damned quote...
    make sure you clean all the old brake fluid, rust and gunk out and assemble with new o rings.
    Cheers,
    Grant...
  8. #38
    Aug 2011
    Canberra
    As my wheel fell off last week due to a failed drum bearing, I'm re-looking into my disc conversion...
    I have everything I need, except for the rare as 3/15 prop valves...
    However, after speaking with one of my friends who works in a brake shop, he suggested that I just cut off one coil from the spring inside a 3/35 unit, which will lower the '35' part of it.
    They had to do it to a car (not a golf) earlier in the week as the rears were locking first, and the technique worked well.
    So, keeping that suggestion for a last resort, I then spent several hours trying to find the spring dimensions that Rocco mentioned above, but to no avail.
    I did however, stumble accross this post on a Lotus Forum
    To progress this to a conclusion I need to know how many people would be interested
    I have the spring spec to convert a Vauxhall valve at 3/what ever to 3/15 so I can get the springs made
    Spring rate 4.58 N/mm
    33mm long
    14.1 od
    10.9 id
    16 gauge wire diameter
    7 coils ground ends
    I have a wholesale supplier that may be willing to sell his stock all be it limited of Vauxhall valves so that may give us 50 or so
    I can get the end that allows the valve to be fitted in the fixed pipe work made to eliminate the problem with stripped threads
    Cost at a calculated guess about £35.00 each for a complete replacement unit.
    Bob
    Indeed, that whole thread is very interesting as the elan uses a similar setup to our Mk1's.
    Also, this post from the same site explains the system, and how it works, very well.
    So, now the questions are,
    Has anyone got a damaged 3/15 they can check the spring size?
    Have you stumbled upon the 'correct spring' elsewhere, and are being 'selfish' and not 'sharing'? (lol)
    Does anyone have some 3/35 valves fitted that they have modified?
    etc.
  9. #39
    Would an adjustable line locker work the same? I've got one that is for preventing the brake fluid building pressure to the rear brakes so you can have the front brakes on (using the brake pedal) and do stationary burnouts on your rear wheel drive car.
    Because I can adjust the amount of brake fluid going through the line locker I should be able to change how well the rear brakes work with a flick of the hand.
  10. #40
    Perth. WA
    Heritage are selling a non oem equivalent.... still pricey tho..
    https://www.vwheritage.com/shop/scir...umbStartRow=33
    My last set of genuines were 104 Euro each....
    Cheers,
    Grant...
