Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: mk1 rear disc conversion
    Perth. WA
    Quote Originally Posted by golfworx View Post
    You also have to get the right valves with the right number stamped on them too. #15 I think
    15 is for discs
    35? is for drums.
    They are completely different & if you use the ones for drums on disc's you'll end up with lock up's. Just like I did, as it allows too much fluid to pass through to the rear calipers!
    Just found a pic of them! # 15 is was!
    the 15 and 35 refer to the cut off pressure the valve is set at, lower pressure one for discs, higher one for drums. The valves are identical internally except for the preload spring. When time permits I will investigate the cost of having springs wound to convert the drum valves to disc valves.
    # for Disc brake valves is 533 612 151 A, and for Drum brake valves is 533 612 151 . neither types of valves have the part numbers on them, only the pressure rating numbers as Tim has said. Beware of buying them of vortex etc as they will sell you the drum ones instead of the disc ones...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Perth. WA
    countersunk will be ok if the fastner is a 12.9 MPa grade. + the loctite of course.
    Cheers,
    Grant...
    Boronia VIC
    New springs would be interesting. 1400 Seat Ibizas have the number 35 valves but I'm not sure if they're openable to swap the spings over.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Perth. WA
    the two sections of the valves pictured screw apart Pete.
    Cheers,
    Grant...
    Boronia VIC
    Seat ones carry the same markings but are manufactured differently, I'll grab a photo tonight.
    Pete
    7? MK1 Caddy
    12 Amarok
    There's a guy on eBay selling those adapters but he doesn't want to ship to Australia .
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
    Dec 2009
    Fitzroy, VIC
    I looked into this conversion, but from what I read the rear disc conversion is a lot more money|effort for a similar result to bigger drums. Added to this the parking brake mechanism is apparently prone to seizing.
    VWvortex Forums: rear disc brake conversion ?'s
    Perth. WA
    The seizing issue was more with MK2 golf/scirocco set ups, likely somewhat due to salt on the roads in colder climates also. The disc set up is heavier than the drum assembly also, increasing unsprung weight. Easier to maintain though I guess... Cost is a factor dependant upon where you source the components from.
    Cheers,
    Grant...
    Boronia VIC
    Left to right.
    Seat Ibiza 3/35 valves
    Scirocco 3/15 valves
    Scirocco 3/35 valves.
    7? MK1 Caddy
    12 Amarok
    Perth. WA
    The SEAT ones look to be crimped after the end cap is screwed in....made by VW i guess as they have a part # on em as well.
    Cheers,
    Grant...
