countersunk will be ok if the fastner is a 12.9 MPa grade. + the loctite of course.
the 15 and 35 refer to the cut off pressure the valve is set at, lower pressure one for discs, higher one for drums. The valves are identical internally except for the preload spring. When time permits I will investigate the cost of having springs wound to convert the drum valves to disc valves.
# for Disc brake valves is 533 612 151 A, and for Drum brake valves is 533 612 151 . neither types of valves have the part numbers on them, only the pressure rating numbers as Tim has said. Beware of buying them of vortex etc as they will sell you the drum ones instead of the disc ones...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Cheers,
Grant...
New springs would be interesting. 1400 Seat Ibizas have the number 35 valves but I'm not sure if they're openable to swap the spings over.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
the two sections of the valves pictured screw apart Pete.
Cheers,
Grant...
Seat ones carry the same markings but are manufactured differently, I'll grab a photo tonight.
Pete
7? MK1 Caddy
12 Amarok
There's a guy on eBay selling those adapters but he doesn't want to ship to Australia .
Audi S3 8L - Stroker GTX3582 700bhp+
Golf GTI 1980
Golf GLS 1979
www.facebook.com/etunersmotorsportau
I looked into this conversion, but from what I read the rear disc conversion is a lot more money|effort for a similar result to bigger drums. Added to this the parking brake mechanism is apparently prone to seizing.
VWvortex Forums: rear disc brake conversion ?'s
The seizing issue was more with MK2 golf/scirocco set ups, likely somewhat due to salt on the roads in colder climates also. The disc set up is heavier than the drum assembly also, increasing unsprung weight. Easier to maintain though I guess... Cost is a factor dependant upon where you source the components from.
Cheers,
Grant...
Left to right.
Seat Ibiza 3/35 valves
Scirocco 3/15 valves
Scirocco 3/35 valves.
7? MK1 Caddy
12 Amarok
The SEAT ones look to be crimped after the end cap is screwed in....made by VW i guess as they have a part # on em as well.
Cheers,
Grant...
