If you've got a rear disc conversion, I'd be highly recommending a 22mm 16v master cyl. & booster conversion.
You'll never look back.
This is the current setup
If your valves are compatible valver (hehe ) Should do the trick nicely!
I think that will be my best option, just a clean swap to the 16v setup. Thanks golfworx, now where’s that Ed
