Page 16 of 39 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 390
Thread: MK1 Ragtop
  1. #151
    May 2012
    Melbourne, VIC
    Quote Originally Posted by MarcusAurelius View Post
    One day bro! Swing past when your back in melb! You still have the blue gti?
    Sent from my SM-G900I using Tapatalk
    Yeh sounds good dude!
    Yeh she's in hibernation for now
    Mk1 Gti 81 2Dr
    Mk2 Gti 88 2Dr
    Mk4 R32 04
  2. #152
    Jul 2011
    Quote Originally Posted by Notso Swift View Post
    I think you now know why I am envious of it
    Haha nothing wrong with a cozy little workshop though
  3. #153
    Jul 2011
    Update!
    So ive got some good bits and pieces from our friendly neighborhood Notso Swift! can not thank him enough!
    I present my new motor, good old adz block but can anyone confirm the head as a mk2 gti? Has a solid cam and 4 injector ports in the head.
    The cam also has 1mm less lift than the one in my fn 1.6, not sure what the go is with that..
    Bottom end seems in good nick, still has fresh hone marks and all, so it's looking promising
    if anyone has a cam theyd like to sell, throw a comment or pm this way
  4. #154
    Nov 2014
    Head was 40mm inlet and 33mm exhaust valves if that helps any one
    What are you going to do about this other one MarcusAurelius? Because I will update the advert
  5. #155
    Jul 2011
    Yep, and twin valve springs too.
    Will contact you in regards buddy
  6. #156
    Oakleigh VIC
    I've got a solid lifter, big duration cam for sale.
    Might be a bit lairy for the street though.
    https://techtonicstuning.com/main/in...48024aeb4b2fd2
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  7. #157
    Perth. WA
    post up the cylinder head part number mate, its cast in above #1 spark plug hole. Early head prob from EV engine code .
    Remember you will need the longer timing belt, and front flange to water pump hose ( from 2. slow engine )
    Are you going with injection or carb induction ?
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  8. #158
    Jul 2011
    Quote Originally Posted by roccodingo View Post
    Will do once im home.
    It will be running a carb, not efi.
    Any reason why id need a longer belt? I was led to believe that the 1.8 and 1.6 are the same dimentions
  9. #159
    Jul 2011
    Heres the head id number
  10. #160
    Nov 2014
    About the same as mine for sale, and not a road cam at all!
