Page 8 of 39 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 390
Thread: MK1 Ragtop
  1. #71
    Jun 2006
    Orange NSW
    Good progress here, mate. Well done! Keep up the good work.
  2. #72
    Jul 2011
    Thanks buddy just have to sort out my seat upholstery skills haha
    Absolutely love how easy door cards are to make. Now contemplating installing a stereo or leaving it out..
  3. #73
    Jul 2011
    So ive come across these 2 canisters. One ive identified as a porsche 914 oem evaporative canister and the other as a vacuum canister in the front right guard. What are their purpose and can i delete them?? Cant find anything in my haynes manual about them
  4. #74
    They are part of the anti-pollution gear originally fitted to the car. Very old and antiquated system, best to leave it off.
  5. #75
    Aug 2011
    Canberra
    Quote Originally Posted by Vinda76 View Post
    Inner cv are triple square as standard, size 8 iirc.
    Assume your brakes are solidddisk, if so can't comment. However 239mm vented are more than adequate for road use even if running with more power. Mk3 booster and 22mm mc is a worthwhile upgrade, makes a big difference.
    Gav
    Quote Originally Posted by MarcusAurelius View Post
    Yepp solid disc, however a gti system seems hard to get a hold of. I'm planning on running the 1.6 for a while so I'll look into calipers and discs later.
    But definately going down the road of a mk3 booster and mc
    From what I've been able to work out, if you already have 239mm disc's, then changing to vented disc's is as easy as just putting them on the hub, and fitting the correct pads (or 20% worn solid disc pads will work too).
    Both brake setups share the same caliper...
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  6. #76
    Jul 2011
    Oh really?? Can anyone confirm that? I was aware that the vented mk1 brakes used the kelsey-hayes caliper, also called the mk2 type caliper
  7. #77
    The calipers are different. The GTI ones are bigger both in surface area and width to fit over the much thicker GTI disks. They use the same mounting points so an upgrade consists of disk and calipers. Standard MK1 calipers won't fit over MK1 GTI disks.
    They make a big difference to the stopping power over standard disks.
    Paul
  8. #78
    Feb 2013
    Melbourne SE
    These calipers will not work
    These will.
    Known as vwii calipers
    Oh and beware, they use different carriers. Which are impossible to get new
  9. #79
    Jul 2011
    Thought so what cars come with the vwii calipers? Gti and cabrios?
  10. #80
    Feb 2013
    Melbourne SE
    Yeah and mk3 polos have them. But you can't get carriers from polos because they're integrated into the hub
