Page 4 of 39 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 390
Thread: MK1 Ragtop
  1. #31
    Jul 2011
    does anyone know what these two hoses are/were supposed to go??
    also noticed the water pump pulley is about 5mm out of line of the harmonic balancer? hmmmmmm :/
  2. #32
    Feb 2009
    Please Enter Location
    Air pump
    Heater hose
    Wrong pulley
  3. #33
    Jul 2011
    Any reason theyd be blocked off?
  4. #34
    Jul 2011
    Also on the lookout for a front driverside quarter panel, rear passanger door and a lock for the rear driver side door, same style as the one pictured above, if anyone has them lying around
  5. #35
    The 2 water hoses go to the heater (under the dash) and back. It's common for a heater to fail on a 35 year old car so some people just block off the rubber pipes. What they should be doing is joining them together so water flows out one and into the other to reduce hot spots in the engine.
  6. #36
    Jul 2011
    But I have 2 hoses going to the heater. I have a hise that comes out the block and into the intake manifold. It then exits the manifold, runs through a valve hooked up to the heater control panel in the cabin and then to the heater motor. Then has a direct return line to the water pump..
  7. #37
    Feb 2009
    No hoses come out of the blockl that I'm aware of.
    This is pretty common sense stuff.
    You are being very naive.
    I suggest you buy a workshop manual and work a few things out for yourself.
    Best way to learn !
  8. #38
    Jul 2011
    Sorry buddy, meant to say 'head' there. Now, as ive already got a copy of the haynes service and repair manual on the way, these are just a few questions ive had. Sorry to do your head in buddy, but im fresh to this sort of stuff
  9. #39
    Jun 2007
    Eastern Suburbs Melbourne
    Hope you're good with a welder!
    i like volkswagens
  10. #40
    Jul 2011
    Have a brother whos a welder by trade so im crossing fingers haha
    Contemplating whether I should rub the whole car to bare metal or not, and how I should go about it
