Page 34 of 39 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 390
Thread: MK1 Ragtop
  1. #331
    First rabbit you hit will wipe out that carbon fibre lip.
    The one I want to fit will be 10mm thick alloy with a skid plate going back to the footwell and enough reinforcement to hit a roo and not come off 2nd best.
    Have you tested the thermostat in boiling water to see that it opens as the water heats up?
  2. #332
    Jul 2011
    I definitely don't expect a long life expectancy out of it haha
    Unfortunately the thermostat is 100% functioning, so whether it's a mk3 thermo advertised as a mk1, I have no clue. The housing itself might be different internally. Either way, the old one was working fine, the original west Germany product MK1 Ragtop
    Sent from my Pixel using Tapatalk
  3. #333
    Jul 2011
    So.. a bit of Dulux gloss white enamel happened...
  4. #334
    Love it. Lot of negative camber on those wheels though. What's your tyre wear like?
  5. #335
    Jul 2011
    The wear is nothing I can complain about. Given I've tracked and dragged the car, however, tyre wear isn't top priority on my list
  6. #336
    Jan 2010
    Melb Westsideeeee
    Looking good man! Love the little CF splitter
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  7. #337
    Jul 2011
    Quote Originally Posted by GeorgeMK1 View Post
    Thanks man when I have time, I'll be attempting the rear arch spats and a rear diffuser
  8. #338
    Jul 2011
    So did a little, check of the motor today that included a compression test and a timing light.
    Cylinder 1: 140 cold / 135 hot
    Cylinder 2: 136 cold / 125 hot
    Cylinder 3: 143 cold / 135 hot
    Cylinder 4: 145 cold / 132 hot
    The plug colours seemed reasonable but plug 3 was much more black. In all honesty, I have no clue how to correctly ready a plug haha
    Also had 10° of advance at 800rpm. I am not running vacuum advance due to the fact the canister on the dizzy is shot and it really runs fine without if. I'll be rectifying it in another way shortly anyway. How much more advance can we get out of the 1.8 8v's??
    All in all, I'm happy the way she runs👌👌
  9. #339
    Number 3 is getting too much fuel or not enough spark to burn the fuel. It's running rich while the others look ok.
    For the timing, at idle advance the dizzy (turn anti-clockwise) until the engine starts to slow down a bit, then turn it back (clockwise) a few mm until it picks up revs again. Take it for a run. If it pings (rattling sound under load) it's advanced too far so turn the dizzy clockwise a few mm.
    Trial and error until you've found that sweet spot.
    Car is still looking awesome.
    Paul
  10. #340
    Jul 2011
    Update on the ragtop
    Catch can, new thermo switch (old one got stuck on..) and... Drumroll...
    5 speed!!!
    Massive thanks to Jordan for pretty much rebuilding it under my supervision and Bryce for letting me use his press for the diff bolts.
    Specs? (Correct me if I'm wrong Jordan) it's a mk2 GTI box with new synchros, mk3 3rd/4th synch hub, diff bolts, new linkage bushes and a TT short shift lever. Modded the 4sp mount and linkages to work with the 5speed. Fair bit of fiddling around but hell yess!!!
