Page 18 of 39 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 390
Thread: MK1 Ragtop
  1. #171
    Jul 2011
    I was kind of kidding, it doesn't really work below about 5000 RPM. Not a street cam at all.
    In any case it's gone up to Queensland to go into a race car now.
    Ah damn haha i was actually considering it
    Sent from my SM-G900I using Tapatalk
  2. #172
    Feb 2013
    Kapunda
    This is bloody cool man, I want to rag top mine
    IG: jackie_melon
  3. #173
    Jul 2011
    Quote Originally Posted by DieselMk1 View Post
    Thanks man!
    well its been a while since ive updated. all the bits came for the adz the other day so i got right into it.
    Full gasket set
    Rings
    Conrod bearings
    Honed the bores
    Lapped the valves
    Shaved the head
  4. #174
    Jul 2011
    Also in need of a crank v-belt pulley, mk1 waterpump pulley and a clutch, flywheel and pressure plate. If anyone has one lying around. Preferably 210mm but anything that will work with the 1.8 and 4speed.
  5. #175
    Jul 2011
    So noone has a clutch handy??
  6. #176
    Jul 2011
    Update!
    So i grew a pair and decided to pull a 210 clutch from a mk3 at a wreckers (shoutout to browneye for being a boss and assisting me on my journey!)
    Everything seemed fine throwing it all together back at home and managed to get the motor back in in no time.
    Spanner checked everything and wire it all up to start it.
    After i prime the oil and get it all ready, i go to start it and fired up like a new car!
    ..one problem though.. noticed sparks flying out of the tdc port on the gearbox.. DAMN
    so box off again, to see what the issue is. Turns out there is a tab in the casting in the bellhousing that was binding on the flywheel.. so out comes the grinder haha
    MK1 Ragtop-uploadfromtaptalk1457159698517-jpg
    MK1 Ragtop-uploadfromtaptalk1457159737558-jpg
  7. #177
    Feb 2013
    Melbourne SE
    The proper solution would be a 5 speed swap mate... I got some flanges if you want to take it down that road, but you would need a mount, which is the real trouble. Hope the clutch performs alright, can't see why it wouldn't.
    Just roof and demister to go?
    Roadworthy here you come
  8. #178
    Jul 2011
    Im pretty decided on running the 4 speed for now. But yeah, demister, fuel pump and install the ragtop and im ready for rego im on the home stretch!
  9. #179
    Jan 2010
    Melb Westsideeeee
    Looking good man!! You will get over that 4sp box reaaaal quick haha. Hope all goes well for rego. Going for full reg or club?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  10. #180
    Jul 2011
    Quote Originally Posted by GeorgeMK1 View Post
    Dunno man, took it for a drive and i dont mind it was thinking of club reg, but might opt for full if i can
