Page 10 of 10 FirstFirst ... 8910
Results 91 to 97 of 97
Thread: MK1 R32 4-Motion Sport
  1. #91
    Oct 2013
    ACT
    So jealous of this. Wish I could do the Quattro build Mk1. But I'll settle for a good run about. And maybe down the track I'll be able to custom build something like this.
    PS: Did you have to widen the track width of the caddy or are you allowed to shorten it in NSW?
    Only The Good Die Young 45
    For a better ride, go WIDE!!!
    VS Commodore V6 Berlina- FOR SALE
    1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
  2. #92
    Sydney NSW
    Hi Mate you can have a customised track width with an ICV.
    I have widened the track width 40mm but it could be widened again now.
    Widening it by increasing the length of the Lower Control arms means having longer tie rods on the steering side of things,
    which works out good for reducing bump steer.
    If the Tie rods on the steering rack are short then the angles they work at become more aggressive as the hubs turn in.
    reducing the track width is going to have an effect on steering geometry that might be difficult to solve properly.
    They take Bump Steer pretty seriously as its an important safety issue.
    Its also important that the rims that are used work to the same offset rules of the VSB.
    this way the rims will not risk the integrity of the hubs and how they were designed to be used.
    so widening the track width beyond the VSB standard by using greater offset wheels is still not
    acceptable.
    It would not make sense to reduce the already relative narrow track width on a mk1.
    You get a lot of gain in performance from widening it
    Also a wider track width means meaty wheel guards and thats goat be good
    The Engineer doing this project has Himself run a pretty big workshop that turned out a serious number of
    Street, Custom, Drag cars the list goes on. So having an engineer that has actually built vehicles himself for a living
    is better than having one that is purposing his career towards certifying mods like engine swaps.
  3. #93
    Stop talking like that, you're getting me all excited.
  4. #94
    Jan 2010
    Melb Westsideeeee
    Fantastic progress mate! Sounds like a lot of work ahead of you in terms of the engineering. All very very worth it I'm sure! Keep cracking at it
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  5. #95
    Oct 2013
    ACT
    Just out of curiosity then, do you know track width of the caddy and mk1 golf then?
    The reson I am asking is because I was told the track width of the Golf is to small to be able to make the Quattro system work. I can't see the caddy and the golf being that much different.
  6. #96
    Sydney NSW
    Track widths are the same, Wheel Bases are different.
    You can customise the control arms, use mk4 hubs,
    and use rims with an offset to bring the track width back to being the same as a mk1.
    Thats one way of doing it...
  7. #97
    Oct 2013
    ACT
    And how much different is the R32 track width from the caddy and the Mk1?
    Because my engineer told me that the track width is to short on the Mk1 Golf hence I can't do the whole quattro build.
