Some new progress on the exhaust
I First planed to have the 2 front O2 sensors where a bouts they would normally sit, but after that
merge the 2 1/4 pipes into one big 3inch high flow cat and then have the rear O2 sensors together.
Even getting as far as starting to build it but realised i could do a better job and also was not so sure i would get the best
out of the ECU so take 2 is looking better!
now using x2 Cats with O2 sensors all going where they should in the circuit.
TAKE 1 Ater which i scrapped the whole idea … Building the exhaust over a mock up Tailshaft ...
So After scrapping that i have gone to a more OEM approach below…
Also not using the whole space up above the tail shaft with a 3inch Cat gives me all the space i need for
-Gear Shifter cables
-Coolant Lines to rear Radiator
-Possibly stainless fuel lines as well
-any wiring to the rear from the dash
I used x2 2 1/4 flanges ground down to mount the x2 flex to, they also made it really easy to connect the 2 1/4 bends
Finished some work on the down pipe and got the engine up and running with all x4 O2 Sensors,
Who doesn't like the sound of an R32 with just a down pipe Prrrrr
