Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 97
Thread: MK1 R32 4-Motion Sport
  1. #51
    Boronia VIC
    You might want to have a think about the underside too.
    You've got a lot of weight over the front end but you might still experience lift at high speeds if you're going to track the car.
    MK1s take off at about 200Km/h. Up to about 180km/h is OK with typical MK1 front profile.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #52
    Sydney NSW
    So mk1's want to fly sometime after 180+ km/h !
    has anyone studied it?
    I was hoping to do some top end speed trials with the Caddy on a long run but i will be cautious about it now.
    Would be great to find out what an ultimate Aero package for a mk1 would be!
    Especially underneath. I am wondering if the Caddy being longer than a hatch mk1 affects
    the figures above on a mk1's top speed for better?
    I want to get to work with an approach similar to the mk2 RWD16v that was being built and showcased onVortex.
    His work under that car was good, sheeting everything off.
    Will be looking into what the effects are of having fins out the back like you see on the rear end/rear underside of track cars .
    aside from that I experimented once with making my own surfboard fins and discovered a little bit of fin goes a loooong way!
  3. #53
    Gosford Central Coast NSW
    Quote Originally Posted by Dub Toffee View Post
    cheers lads
    Interestingly a study has this to say
    " Velocity field measurements of the near wake flow show a relatively quiet region behind the cab and no recirculating flow region in the symmetry plane behind the tailgate.
    Instead there is a strong downwash at the symmetry plane behind the tailgate. This downwash is due to the existence of a pair of counter-rotating vortices downstream of the tailgate.
    The downwash promotes attached flow behind the tailgate, thus resulting in a pressure recovery that reduces drag. " thumbup:
    This is the same kind of aerodynamic concept that was utilised on the Mk1 hatchback - the inset rear window causing vortexes to shed at the back aiding attached flow at the very back of the car.
    Good for economy, not ideal for downforce though
    The trans tunnel looks amazing man. I can't believe its on its wheels!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #54
    Sydney NSW
    thanks mate, thats interesting info on mk1 Aero
    wouldn't it be great if someone with money in the UK etc messed about with mk1's a wind tunnel and building a competitive Aero package
  5. #55
    I would have thought probably the kamei kits would have been well researched in their day. Front end aerodynamics of cars, in sofar as the knowledge possessed by designers, probably hasn't changed a great deal in 30 years. However, what happens at the back and underneath has certainly advanced a lot - so you are right on the money in terms of looking into underbody and rear diffusers.
    Also, I think they have a nascar truck series in the US..... IIRC, they have some very 'agricultural' looking aero devices that are in fact very effective.
    '99 A4 Quattro 1.8T
  6. #56
    Sydney NSW
    yea i seen the nascar ones and its just as you said.
    I mentioned on vortex a while back and realised i didnt put it on here but i was looking at
    the idea of playing about with ballast in rear. If its not to much extra weight the benefits of cornering
    with a more equally balanced vehicle might out way a small loss of acceleration.
    IM keen to see how 4-MOE goes with wide tyres!
  7. #57
    The HSV Maloo (VE) has 50kg of ballast at teh rear axle.
    '99 A4 Quattro 1.8T
  8. #58
    Sydney NSW
    What!
    I mean its something i have seen in Ship building and aerospace but not production cars.
    I guess the fat Auzzie business owners that i seen drive them have a good reason to loose 50kg haha
    the Maloo is a brute tho and at least holden have got out some iconic cars before volkswagen take over the world haha
  9. #59
    True!
    Having only been a passenger in one I can only give a rough indication, but I would have said it was a worthwhile, if a bit silly, addition to the maloo. It certainly seems to have better handling balance than the SSV, etc. Way more rear grip than I thought it should have, anyway. Then again, 275 rear tyres are also pretty huge.
    Regardless, I think the caddy will be leaps and bounds ahead, given the lovely 4-mo drivetrain
    '99 A4 Quattro 1.8T
  10. #60
    Back in the Dark Ages when I was a lad we found that the old Holden HR ute would handle heaps better if there was a hay bale in the back.
    The only thing we knew about weight distribution back then was never give a lift to a fat chick if you wanted to set a good time between Katoomba and Lithgow.
    Paul
