The globe you're after has a P45t base.
Narva still make 'em and you can get halogen versions.
Pete
Hey All!
i just wanted to know if any of u guys knew what the bulb was called that is in a mk1? Its definitely NOT an H4, It is an HB4 or something like that? I know u can do the H4 conversion on them but i havn't and i want to upgrade my headlights cos they look rubbbish.
let me know!
Rach
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
JUst found a Narva box in the garage.
Markings on the box are
12V 100/90W
P45t-41
44392
48904
Barcode number is
4 013790 325082
That should be enough info for you to order some in.
7? MK1 Caddy
12 Amarok
make sure you do the relay upgrade too, this will help till no end!
I already have relays on the high beam lights (the inside ones in a gti grille)
pete - I tried the barcode number and the part numbers in my system @ work and they come up saying it is a 90/100W h4 Bulb.
Thanks anyway,
Doesnt much matter now i've decided im just going to try and convert it to an h4 globe. I've put a post up in WTB regarding it.
Thanks
x
I just investigated this on my golf, and I'm running P45t globes 45/40W - Pete, your saying the lamps are rated to cope with 90/100W? I've done the relay mod already.
Did you find an adaptor Rach? If not these look the go.
Hemi Performance: H4 Halogen 100/90Watt P45T Globe - AU$17.50 (Powered by CubeCart)
Here is some more info Rach. The globes that Pete suggested are H4, but, are using the P45T-41 base so will fit your lamps. The modern H4 globe uses the newer P43T-38 base your referring to. The H4 is referring to the shape of the bulb and the filament number (and I believe Halogen filled) and the old incandescent are R2.
Automotive lamp types - Wikipedia, the free encyclopedia
Heck the more I google the more I learn.
Here are the P45T to P43T base adaptors you were talking about Rach on eBay.
P45T TO P43T H4 HEADLAMP ADAPTERS VINTAGE CLASSIC 2CV (eBay item 280510406437 end time 17-Apr-11 07:35:47 AEST) : Vehicle Parts Accessories
This deserves a listing in the FAQ haha.
