Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Mk1 needs more low!!
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by Ak1 View Post
    Yeah, coming to the feeling that bags are the only way to get what I want so many dollars of money though!! Anyone know a cheap place to get it done. Best quote I've had so far is 5k engineered!
    5k for someone else to do it and engineer it is cheap!
    i like volkswagens
    Jan 2010
    Melb Westsideeeee
    Shutup jarred, its expensive and no one should do it
    But yeah as Dom said, drop plates and extenders will be more than enough. I managed to get 2cm off the ground without drop plates or extenders. So it just shows you can get low with the right wheels and tyres. As for ride comfort, i can tell you that no matter what car you lower, if its properly lowered it will smash the ground always. But yeah dude, get some strut top extenders, and some decent coils (i recommend ST coils if you want bang for buck) and you're set man.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Feb 2007
    I don't have a problem with my cheap adjusties (hottunning). Yeah its stiff as **** but its not unexpected when its like 2" from the bump stops. Id rather have it stiff with less travel so im not slapping the ground with the sump over every tiny bump. Strut top extenders work well to soften the front up but keep in mind the extra travel.
    It did help a fair when i cut the bump stops in half and when i raised the front, even just a touch it made a big difference, i feel as if most of the **** ride is due to the front being low.
    With normal wheels and tires it will ride fairly normal, minus all the body roll. I've been in a slammed mk1 with KW coils, didn't really feel a difference, still rides like a slammed mk1.
    If you are guna slam your 70s car and sook about it being rough your in the wrong game.
    Bags and engineers for $5k is spot on.
    MK1 GLS 3door
    A4 B7 2.0T
    bags installed and engineered for 5k is cheap!
    but keep in mind, bags dont always mean lower. Depends a lot on brand, type, struts used, design
