Results 1 to 10 of 11
Thread: MK1 manual conversion
    Sep 2005
    As some of you know ive got a 1977 mk1 gls golf, pure old ladies car, complete with auto box.
    I have the whole thing appart at the moment and figure its the best time of any to do a manual conversion.
    Interested to know how hard this is to do with the old golfs and what parts are needed etc.
    Is it harder to do 5speed conversion and can 4 speed clutch pedal box etc be used?
    This is all new to me and any help is appreicated.
    Gosford Central Coast NSW
    i havn't done the conversion - but the gearbox is independent of any of the pedal stuff so if you make it work with a 4 speed, it'll work with a 5-speed too.
    i should think once you swap the pedal box (and the rack! yuk!) all you'll need to do is find the shift linkages and rods and stick. you may not need to swap the rack if you can make up some of your own bracketing to hold the gear linkages.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Sunny Coast - The QLD
    If I was you I would go straight for a cable shift gbox. You need to make up some custom mounts for the gbox side and rear but it is a better system and will give you a better shift than the old linkage system. Just my 2 cents. Good luck.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Aug 2005
    The 1600 won't have enough torque to pull over the tall cable shift ratios (or turn a 228mm flywheel and clutch set-up). You'd need a 4.24 ring and pinion to give you similar effective ratios, which would complicate things a lot more too... and add a lot more expense
    The easiest way to do it is to buy an unregistered manual Mk1 (plenty pop up on eBay), and swap everything over from there. You know how everything bolts together then It would only cost you a few hundred bucks that way - mind you, I'd replace the clutch and rear main seal while you're at it. HTH
    Dec 2006
    Kilsyth, VIC
    The last conversion I did was helping a mate swap out a full engine and gear box from one Torana to another. The install itself was straight forward since we were basically able to unbolt from one car and bolt into the next. The problem we had... Starting the car.
    It just wouldn't crank at all.
    Checked all the electric system and they were powering right, checked everything else we could think of. Still no joy.
    Anyway, we went about tidying everything else up while we pondered calling in an expert or towing it to one. Then it hit us. An auto box has a circuit in the shift lever that means you can only start in Park (and usually neutral) but not when the car is in gear. *smacks forehead*
    We had carefully unbolted the switch and hid it up under the dash, problem was we didn't actually bridge it
    In the end my mate made up a removeable jumper so it basically acted like a kill switch.
    Just thought I would mention is since it caused us so much grief.
    Camden, Sydney
    Mk1 pedal box is easy, pedal just hangs off the end of the column.
    I`d do it with a 4 speed first, as its cheaper and easier to get/
    What cable shifts have a better shift than the rods Gotrice? I think they feel vague and slushy.
    like an asian car...
    anyhoo, i'd say do the whole shebang from another car... how long can you wait? i might have the parts for you in a month or so if you like. only trouble is the rack mounts... actually i think my rack mounts are the later kind...hmmm
    aydan
    '99 A4 Quattro 1.8T
    Talking
    Yeah my rod shift looks like it did 2,000,000 kms and is a little sad! LOL I even changed all the easy to change bush's and its still sloppy jo loppy. Need to do it properly I guess.
    I'm with Valver on this.
    It would be easier & cheaper to buy a whole unregistered car & do the swap.
    Then you get everything incl. all the little bit's & pieces eg. Manual steering rack, manual starter motor & battery lead's, flywheel & clutch assembly, clutch cable etc.
    As the Hawk also stated, Remove the auto selector wiring too. Or you could make it into a kill switch arangement too!
    What are your plan's for the auto box?
    Sep 2005
    Sorry guys been flat out lately! Studies.
    Im heaps unsure if its worth the money and trouble to do the swap, i was amazed at the auto when i got the car as i was expecting a slug. Its all very original atm and sounds pretty nasty to be swapping racks etc.
    I can get 4 speeds and all the gear easy in whole car or sperate for few hundred but am i going to be getting a much better ride?
    Will it make it easier to resell one day or is orginal better?
    I have the feeling being an old ladies car auto GLS its prob best to leave it and continue till maybe 1 day a 16v.
    Appreciate all oppinions. Ive spent alot already but do love them.
    Thanks
    Again all
