Results 1 to 9 of 9
Thread: mk1 manifold gasket?
    hellp
    just wanted to check
    Does a mk1 need a manifold to exhaust gasket or just bolt straight on??
    1977 VW Golf Mk1 Baby Blue
    1999 Audi A3
    Sep 2009
    Chillaxing in Tas
    should use a generic 3 bolt flange gasket near the steering rack assuming you have the stock exhaust, i find using a sealant like Maniseal works awesome
    <space for rent>
    ah yes i have that, what about manifold to engine block? thanks
    1999 Audi A3
    Boronia VIC
    Needs 4 gaskets. Like this.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    do you recommend buying through german auto parts.com, is their postage reasonable.
    anywhere else i can buy them
    thanks for your help
    1999 Audi A3
    Sep 2009
    Chillaxing in Tas
    Camden GTi sell them in sydney,
    <space for rent>
    Feb 2009
    NSW
    Brian at Gti imports, Dural has these.
    Boronia VIC
    Not worth shopping overseas for such small order.
    I just used that pic to show what they look like.
    Typically GAP won't accept an order below USD100 for international shipping in any case.
    ANy of your friendly local VW parts places should have them.
    Tooleys would be able to post you a set.
    Worst case VW spare parts department will have them, they're the same as on the MK3.
    7? MK1 Caddy
    12 Amarok
    awesome will try them.
    on an other note i am about to re connect the uni joints, should i clean and regrease? (there is still quite a lot of grease in them) what sort of grease?
    any help on this would be much appreciated as you may have already guessed I'm pretty rookie at all this
    1999 Audi A3
