should use a generic 3 bolt flange gasket near the steering rack assuming you have the stock exhaust, i find using a sealant like Maniseal works awesome
hellp
just wanted to check
Does a mk1 need a manifold to exhaust gasket or just bolt straight on??
1977 VW Golf Mk1 Baby Blue
1999 Audi A3
<space for rent>
ah yes i have that, what about manifold to engine block? thanks
1999 Audi A3
Needs 4 gaskets. Like this.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
do you recommend buying through german auto parts.com, is their postage reasonable.
anywhere else i can buy them
thanks for your help
1999 Audi A3
Camden GTi sell them in sydney,
<space for rent>
Brian at Gti imports, Dural has these.
Not worth shopping overseas for such small order.
I just used that pic to show what they look like.
Typically GAP won't accept an order below USD100 for international shipping in any case.
ANy of your friendly local VW parts places should have them.
Tooleys would be able to post you a set.
Worst case VW spare parts department will have them, they're the same as on the MK3.
7? MK1 Caddy
12 Amarok
awesome will try them.
on an other note i am about to re connect the uni joints, should i clean and regrease? (there is still quite a lot of grease in them) what sort of grease?
any help on this would be much appreciated as you may have already guessed I'm pretty rookie at all this
1999 Audi A3
