Results 1 to 10 of 15
Thread: Mk1 golf help
    May 2012
    Tullamarine
    Mk1 golf help
    Hey guy I'm just in a predicament at the moment. I've got a 4speed diesel gear box and I just brought a 1.8l 8 vale engine block, im about to replace the clutch before Assembling them together, is there a specific clutch I need to install or just a standard NA clutch.
    Feb 2009
    Please Enter Location
    You wont like the final drive ratio of the diesel gearbox,it will rev its head off.Oh about the clutch a standard one will be fine.
    May 2012
    Tullamarine
    Thanks buddy, If I get my hands on a 5speed is there any modifications I will come across by or will it just sit straight in.
    Feb 2009
    They bolt up to the block the same.Some have a different sized input shaft and drive flanges and you will need a 5 speed gearbox mount and mod the linkages.Petrol 4 speed boxes are cheap as and work well.
    Jun 2008
    Hobart, TAS
    A 5 speed Should fit straight in, although you may need to change the mechanisms (linkages, etc) to 5 speed ones to get it functioning properly, its not a hard job though
    What year/model is it?
    May 2012
    Tullamarine
    It's a 1980 GLD, ive taken out the diesel motor and replacing it with a 1.8l 8v motor. I'm trying to reuse some parts which can also adapt with both motors. It's not going to be a everyday car that ill be driving in and I'm aware of the final gear ratio on a 4 speed box.
    What are your thoughts. Should I Just leave the 4 speed box
    Jun 2007
    Eastern Suburbs Melbourne
    unless you do lots of hwy kms,the 4 speed will do fine, imo.
    i like volkswagens
    May 2012
    Tullamarine
    thanks for the help guys, really appreciate it !
    Peregian Beach
    I believe you are getting it wrong. A diesel engine revs a lot lower than a petrol. Therefore the gearing in a diesel gearbox (ie final drive ratio) is much taller (smaller numerically). So rather than screaming its head off the revs will be lower for a given speed than for a "petrol" gear box. This would make highway cruising easy so long as the engine has the torque to pull it. A 1.8 should handle it quite well.
    Feb 2009
    Quote Originally Posted by Bora Sport View Post
    You are wrong.Do the research.I couldn't be bothered seeing you don't want to agree.
