Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: mk1 golf goes broom broom
  1. #21
    PERTH
    very close just need a head and afew other little bits and peices and chapowwwwieee another golf back on the road.
    the golf is not dead.
  2. #22
    wat bout the head that golfwise has?
  3. #23
    sydney
    hey bro did you source some poly bushes??? i am interested if you find a source
    and by the way http://photobucket.com/ will host your pics for free
  4. #24
    PERTH
    i will be changin the bushes later on i decided when the car is running so i can just drive it in to the pros and drive out with it all done, as you guys say some need to be pressed in so ill get a good job done.
    as for the head, ,i can get one but it will cost me a little bit more and i can pick it up plus it has a warranty on it so ill will be getting that one not the one in tassie, and wont be breaking the bank.... but i know if i get the head now i wont fix all the little things wrong with the car, while its off the road im fixing everything! so im getting it to the stage wheer i can just buy the head bolt/hook it up and drive a nice car with the thought that nothing is wrong with it at all.. and im nearly there folks, nearly there
  5. #25
    sydney
    how did you role those arches?? if you dont mind helpin a brother out.not the baseball bat??i hope
  6. #26
    PERTH
    close to but no
    striped the paint of with a crazy spining wire brush back to bare metal, heated the arch up with a propane torch grabed a bangstick and a body repair kit, dolly in different shapes, hit the buggery out of the untill they were a relitivly nice shape i wanted, metal filled any weird bits in the arch , i didnt use body filler as i dont beleive in body filler maybe on a jap car but our vws should have the best of the best, but after the meatl fill i did use a tiny bit of filler, which im not to proud of, then the whole painting process,
    NOTE. was hard to blend new paint to old but buffing during each layer of paint should fix it, which was my mistake.... i didnt do it
    but the rear arches were harder as its twin plated so i had to a bit of cutting, and welded a little extra steel to the bottoms of arch and made it look like try hard WRC style, different to the front as the front slope in and dont flare out as much... now i need bigger wheels!!! might redo the rear, not sur yet...
    but this let me lower the car i tiny bit more with no rubbing at all and creates that unique stance
    and if anybody knows how to bring the rear out about 20-30mm safely please let me know, even if its a hub change?
  7. #27
    sydney
    i made some hub spacers for my mk2 a few years ago basically spaced the hole hub brake and so on out. basically a plate with holes to space the hub off the trailing arm think they are in the garage i dont know if they will work on a mk1 though ?? or hubcentric spacers h&r are the go.
  8. #28
    PERTH
    i have H&R 5mm on the rear at the mo and i thought that was max but how far can u go with original bolts< where do u get longer bolts? do u need longer bolts?
  9. #29
    sydney
    on my mk2 i have 25mm adapters and 20mm spacers 45mm of spacing, they bolt onto the hub and then you bolt onto the adapter check h&r trak+ hubcentic spacers and all shall be explained
  10. #30
    TassieGTi Guest
    Obviously parts from Tassie aren't good enough!
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Electrical problems with VW Golf V towbar
    By JandG in forum Mk5 Golf & Jetta
    Last Post: 08-03-2009, 08:50 PM
