![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
finemk1
ok so i tried a dummy run with a push button as you said loon, it cranked over but slower than usual, so i pulled apart my stering column and things had been hacked at when my alarm and central locking went in but after a bit of solder and tape still no go,, the plastic switch looks fine and i cant see any other probs so i turned to the fuse box DUHHHHHHHH
when ever there is a problem with my golf i allways think its major... ive lent my lesson ALL WAYS CHECK THE FUSES FIRST
3 fuses were blown so i replaced ALL fuses, i found they were sitting in the holders fairly loose which was producing sparks, so i just bent them closer with pliers and whoshka the ignition worked and cranked over, but still at a slow rate
stay tuned to this bat station...
I would seriously check your battery and engine earthing, can be a suspect when the starter cranks slow.. run an earth from the engine to the coil bracket also..But yeah, the ol' MK1 fuse box / relay plate is one major headache ...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
