Results 1 to 4 of 4
Thread: MK1 Golf Fusebox – Relay help
    Apr 2009
    Please Enter Location
    Hi all
    Please help, 2 years ago I pulled my electrical loom apart and didn’t really do a good job of labelling things.
    Now I’m stuck as to what wires go where in the upper terminals G&H? I’ve tried everything, searched all over the web and worked off the Bentley manuals for the correct wiring diagram.
    The problem I have is every wiring diagram appears to have a slightly different layout
    I would really appreciate it someone could let me know where the wires should go or even better send a picture of their fusebox with these wires in position.
    The car is a 1977 or 1978 Auto MK1 golf
    Thanks
    Martin
    -20140127_194820-jpg
    -20140129_063836-jpg
    -20140129_063845-jpg
    -fusebox-jpg
    Aug 2011
    Canberra
    Although a little newer than your car, the Cabby-Info site has some info...
    Electrical System
    Also, their Supplemental PDF could help...
    http://www.cabby-info.com/Files/ElectricalSystem.pdf
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
    Aug 2011
    Canberra
    Here's another pic I stumbled across...
    Apr 2009
    Thanks guys
    It turned out those connections as circled in yellow had nothing to do starting the engine.
    The main thing I wanted to do was to be able to start the engine. After chasing the circuit around with a multi meter it turns out the small copper connector that’s mounted on the base of the auto stick lever was not bridging the power over to the starter motor. After taking this off, cleaning, re-checking it allowed the current through and I was able to start the engine. Also the auto level needs to be in park or neutral.
    Last night the engine fired up for the 1st time in 2 yrs..Its load though with no exhaust!
