Hey everyone,
Swapping out my points dizzy on my '78 1.6L MK1 Golf as its giving me grief and wanted to know if this MK2 dizzy would be a direct bolt in. VW GOLF JETTA MK2 1.6 1.8 GTI 8V DISTRIBUTOR + ROTOR ARM CAP 027905205S A449 | eBay
I also know you need to run an ICM for the timing. But if you have an MSD 6AL cant you bypass the ICM since the ignition box has a wire for the dizzy signal?
John
1978 MK1 1.6L 8v
2007 MK5 3.2L 24v R32
Why do you need a new distributor?
If the old one is ok you just need a conversion kit to replace the rotor.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
