Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Mk1 GLi ?
    Feb 2007
    Mk1 GLi ?
    Hi all, fairly new to da scene, still learning.
    I bout a 1979 GLi 4door a couple of years ago for my first car (still in the gurage waiting for the primer to be sanded )
    I've been looking around and there seems to be no information on a mk1 Golf GLi. I cant find anything from 1979 with injection and 4doors.
    Can some one help me out here? Is this a rare golf or something?
    So far all i know is that is '79, 1.6L (not even 100% on that), injection, automatic, 4doors and made in germany. Ive got a manual book but it doesnt say anything about GLi.
    Just wana get some knowledge.
    I have not heard of a GLi except in cabriolet form.
    Germany got a 4 door GTI I believe. Has to be 1600 pre 83 model year. Engine code probably EG unless it has had a transplant.
    Top hose exits head between plugs 1 and 2.
    Feb 2007
    Quote Originally Posted by h100vw
    WHOA WHOA, slow down.
    Im newbie. Top hose exits head between plug 1 and 2?
    Sorry, got a lot to learn.
    MK1 GLS 3door
    A4 B7 2.0T
    syncro Guest
    Does it have an Australian compliance plate with ADRs listed?
    On a 1600 motor the top hose to the radiator leaves the head between plugs 1 and 2 counting from the left(timing belt end). The 1800 engine has the top hose leaving between plugs 3 and 4.
    The 1600 comes out at about 45 degrees and the 1800 is perpendicular to the head.
    Photos are always going to get an accurate response. Personally I reckon someone built it up.
    Feb 2007
    Heres some pics before I striped it:
    http://img165.echo.cx/img165/6301/pic00224te.jpg
    http://img165.echo.cx/img165/4006/pic00194ve.jpg
    And the engine:
    http://img231.echo.cx/img231/2153/pic00237ms.jpg
    The head number thingo is 049103373 2BR, Brazil, not germany. Is that a bad thing?
    The intake manafold says 079133223 Germany......
    One guy once told me to be thankfull it wasnt made in southafrica and that it was made in germany.....but its not german either.
    Quote Originally Posted by syncro
    Yeah its got that plate.
    MK1 GLS 3door
    A4 B7 2.0T
    That's a 1600 engine for sure. The engine number is on the block behind the dissy. It should probably start with EG.........
    The other numbers you posted are the part numbers.
    It looks like it might have some emissions equipment on it, as there is a couple of things I don't recognise from a UK engine.
    syncro Guest
    I'd say that it's a modified Australian '79 GLS
    Feb 2007
    Its got air con, could that be the things you dont recognise from UK engines?
    By dissy, do u mean distributor? I couldnt find the engine number on the block so maby its behind something I cant move.
    MK1 GLS 3door
    A4 B7 2.0T
    yes by dissy he meens distributor
