Results 1 to 10 of 10
Thread: MK1 GLD Golf
    Apr 2011
    tyres size is an important consideration when picking widths/offsets/sizes etc, so keep that in mind too.
    Yes, standard mk 1 chrome bumpers will work. (good luck finding a pair ;P) you'll just have to block up the small holes from the side supports of the plastic bumpers if you switch. (or weld, fill, respray if you're that talented or committed)
    Yeah, I can imagine finding them will be hard, especially here in Aus. It needs a bit of touch up paint here and there because unfortunately the car is parked outside due to the other newer car occupying the garage.
    Oct 2006
    Albany Creek Brisbane
    If you want to get rid of the black plastic piece at the rear under the rego plate, I am interested in it.
    Let me know
    Thanks
    Apr 2006
    Melbourne, Victoria
    Get rid of the oil cooler. It serves no purpose on a 1.5D. If you want to keep the standard motor I suggest a cordoba 5 speed box along with the flywheel and clutch, replace the exhaust from the manifold back, including the tiny flex section and then consider the governor spring. Then you will be able to cruise comfortably at 130 kms/hr.
    THe motor will last forever as long as you dont cook it. The best way to prevent it from overheating is to replace all of the coolant hoses. It may cost you a few dollars but it is worth it. THe hoses under the injector pump are particularly susceptible to failure due to exposure to diesel fuel. I have had the hose from the head to the water pump fail on two different cars in exactly the same spot
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Oct 2006
    Where is the best place to get a set of replacement hoses for the GLD so I can do this job sooner rather than later? Can you buy complete sets or individually?
    Thanks
    Apr 2006
    Melbourne, Victoria
    I've purchased hoses off German Auto Parts in the USA. THere may be other cheaper suppliers though.....
