Results 1 to 10 of 12
Thread: Mk1 Gearbox
DubSteve Mk1 Gearbox 15-01-2009, 11:11 AM
XXX-1.8T sounds like its the gear... 15-01-2009, 11:46 AM
DubSteve Hope so mate I bought a new... 15-01-2009, 12:02 PM
gtimk5 Very easy fix there, gear... 15-01-2009, 12:15 PM
DubSteve Cheers Andrew will try that... 15-01-2009, 01:06 PM
XXX-1.8T yeah happened to my wife when... 15-01-2009, 02:25 PM
gotrice I had the same problem. I... 15-01-2009, 05:36 PM
gtimk5 Well Steve, you asked the... 17-01-2009, 11:10 AM
    Sep 2006
    Australia?
    Hope so mate I bought a new gear linkage kit from GAP and I have it at home, as I wanted to get the wonkieness out of the throw hopefully I can kill two birds with one stone
    Apr 2006
    Hobart,Tas
    Very easy fix there, gear knob off and the boot. Slide the circlip back down into its groove. Common problem. Tighten the circlip carefully with pliers before refitting it into the groove. You will see the groove when you lift the lever up and push down on the spring part.
    Sep 2006
    Australia?
    Quote Originally Posted by gtimk5 View Post
    Cheers Andrew will try that out mate.
    Sep 2005
    Maroubra Beach
    yeah happened to my wife when she had the Mk1 thought she broke it and went nuts at her
    Sunny Coast - The QLD
    Talking
    I had the same problem. I bought a cable shift box and that fixed it up all good. Ooooh yeah so much cable shifting goodness!
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Apr 2006
    Hobart,Tas
    Well Steve, you asked the question the other day, thought you could tell us your fix.
    Sep 2006
    Australia?
    Hmm not to sure Andrew the mechanic I went to did solve the problem however to get into first I need to press the gearshifter half way down and then push it towards the gear 1 and as for 2.
    However 3,4,5 are ok, I am not sure what he did
