Results 1 to 10 of 14
Thread: mk1 gauge problems
    Dec 2010
    Seaford SA
    mk1 gauge problems
    my temp and fuel gauges working however as i was driving both gauge needles dropped to zero now nothing raises up so i dont know h0w much petrol is in the tank what happened ? how can i remedy it. thanks
    Sep 2009
    Chillaxing in Tas
    as both died at same time, id assume its something to do with the cluster.
    Cause the temp sender and fuel sender are at opposite ends of car
    Other then that i dont know, i dont think there is a relay or anything to control them.
    <space for rent>
    Jun 2007
    Eastern Suburbs Melbourne
    there is a voltage regulator that controls the function of both of the gauges, it's on the back of the instrument cluster. COuld be that.
    i like volkswagens
    Sep 2009
    Chillaxing in Tas
    is that the bit with 3 prongs and a screw to hold it down? or am i thinking of the old corolla dashes? cant remember
    <space for rent>
    Dec 2007
    Somewhere in Melbourne, Victoria
    Agree that it sounds like the Voltage Regulator. Get yourself a new one (they aren't that dear from memory) and replace by removing the instrument cluster. Be careful with the printed circuit sheets as they tend to weaken with age.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Jun 2007
    yep, that's the one.
    I'm sure having a quick search show net a few posts with pics about it, and it's replacement etc..
    i like volkswagens
    Sep 2009
    Chillaxing in Tas
    be carefull with the prongs, some douche didnt screw mine down before i got it, so a wire from the headunit somehow wrapped around it and when i went to pull it out it snapped the regulator off... i just swapped to spare cluster i had.
    Pretty sire my old corolla has same setup :S, cant remember, been a while.
    <space for rent>
    May 2010
    NQ
    All my gauges dropped out when the voltage regulator on the alternator "died", resulting in the gauge cluster fuse blowing.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Dec 2010
    Seaford SA
    Quote Originally Posted by paulie71 View Post
    thans for your help
    Jun 2007
    Quote Originally Posted by ryana89 View Post
    IIRC., don't think the mk 1 has a fuse as such for the cluster. The tacho and speedo are mechanical, and the lights have fuses, but I'm pretty sure the voltage reg takes care of it, instead of a fuse. (also drops voltage too, as the name would suggest.)
    i like volkswagens
