out of curiosity - why?
Im looking at rewiring my 77 gls what are the options for a fusebox upgrade ?
Dose anything fit in the original fusebox carrier ?
2001 black gti 18" tt rims ,kmacs and a big dent (daily until rego runs out and mk1 is painted )PHP Code:
mi
76 gls 3dr agu ( build in progress, )
77 gl parts car
You can upgrade to a VW CE1 fuse box/relay plate. This will involve repinning all the wiring on the existing harness' to the CE1 terminal ends.
You will likely need the correct wiring diagrams to cross reference pin locations and tools for removing the terminals from the existing terminal ends.
There are loads of resources on various forums out there, just do a search .
Lots of MK 1 Scirocco's...
Cheers,
Grant...
All of them?
I thought it wasn't until the MK2 came out that Golfs had working lights.
And a heater.
And door handles that worked.
