Results 1 to 9 of 9
Thread: :?:MK1 fuel problem:?:
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    Question :?:MK1 fuel problem:?:
    ive got a mk1 running the mk2 k-jet ev engine and my prob is the car is hard to start when i leave it for about 20 mins - 2 hours, it starts fine when totally cold and after about the 2 hour mark, and it starts straight away after i go for a drive, the guy i bought said it was the accumulator but every mechanic says somthing different. and most mechanics dont know s*** about k-jet systems.
    HELP!!
    Camden, Sydney
    If you turn the ignition on, the pump should start to build up pressure. Let the pump cyle for a minute, then try and start the car. If this works, it is probably the accumulator.
    On the mk1 the fuelpump is primed by the relay when you shut the ignition off. The mk2 relay runs the pump when you turn the ign on.
    I used to swap the relays on mk1s for mk2s, that way you can flick the key on a couple of times and get the fuel pressure up before going for a start.Not sure if the relay will go in the early ceramic type fusebox. It definitely works with the later blade fuse type. It would be too hard to do an extension wiring job on the relay to make it run the early fusebox though.
    You are probably not in th emarket for one but this gauge kit is the thing to diagnose pressure issues on Kjet.
    http://cgi.ebay.com/ebaymotors/FUEL-...32027497QQrdZ1
    EDIT found a cheaper one
    http://cgi.ebay.com/ebaymotors/Tool-...spagenameZWD2V
    Camden, Sydney
    This car is a non genuine Mk1 injected. Who knows what wiring is hooked up to the pump. I see lots that are hard wired!
    Jul 2006
    yeah the wireing on this car is a nightmare.. thats the mian problems that ive had soo far but the engine has only about 150,000ks on it so it drives well. (when i get it started)
    another thing the fuel pump is noisy does that mean its old and worn out??
    Jul 2006
    oh and another thing, i dont know if this is related but if i put my foot down a little through a corner or big round about it fells like the car starves itself of fuel and jerks before a boost of acceleration. if any1 can shed some light or had a similar problem. post
    K-jet fuel pumps get noisey when they are straining to get fuel. Particularly true of MK2s when the lift pumps have failed. Have you had a look into the tank through the access panel under the back seats?
    Has the fuel filter been replaced ever? Have a look through a Haynes, it tells you how to do an flow test. You jump the fuel pump relay and then see how much fuel is pumped out in 30 secs.
    Is that lefthanders or right handers that produce the jerking on acceleration? I wonder if it has a carb tank fitted which won't have a collector for the pump pick up. Unless the tank is pretty full the fuel will be surging away from the pick up and causing the starvation.
    Perth. WA
    Quote Originally Posted by h100vw
    This sounds like the real problem, It'll be causing your pump to prematurely wear out also..
    Ya need someone who knows what's supposed to be there to view it
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jul 2006
    it staves around both left and right hand corners, and when the tank is full or empty (nearly). but i can drive it normal and wont it happen.
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Tigar VR6 fuel problem
    By JET-28L in forum Mk3 Golf & Vento
    Last Post: 30-01-2007, 02:32 PM
  3. Diesel Fuel lines
    By smithy010 in forum Diesels
    Last Post: 18-11-2006, 06:04 PM
  4. help.. fuel problems!
    By mollins in forum Mk1 Golf
    Last Post: 07-05-2006, 02:21 PM
  5. Getting fuel in the carbs
    By worm in forum Mk1 Golf
    Last Post: 22-04-2006, 05:25 PM
