Originally Posted by
eltonking
I've got an 1800 RV (mk2 GTI) and it seems as though it was a bolt in ordeal, engine mounts are the same, dizzy, fuel pump is still mechanical and its still running the standard 4 speed that was originally mated to the 1.6...
I've also teamed it up with a TS passat manifold and 32/36 weber carb and it goes well, just picked up a 272 cam which will be going in shortly.
Pete, I'm looking into a new clutch but obviously given the differing engine/gearbox combo not sure what size clutch i'm after... is it the 210mm or 180mm(or 190mm) or whatever I should be picking up?
cheers!
