Results 1 to 10 of 11
Thread: Mk1 Engine Mounts
    Oct 2006
    Hobart, Tasmania
    Mk1 Engine Mounts
    Hey i dont know if this forum has already been created but anyway, do any of you guys know of a good engine mount to run that would be stronger than the standard, I have swaped my engine mount for a new one (standard part) and It broke aswell. The engine mount is located on the drivers side.
    cheers luke
    1977 VW golf 3 door
    Toyota 4AGE Khanacross car
    Gilera Runner 180cc
    Are you talking about the rubber guts of the mount or the steel that it sits in?
    I had a 2 litre big valve MK1 years ago and only uprated the rear gearbox mounting and the front snubber. I had no troubles with the side mounts. This is where all the movement happens. If they are slack, then the side mounts get twisted continuously which doesnt do them any good.
    There is a right and wrong way round to insert the side mounts if you take them out.
    This is the kind of thing to find in the States I reckon. Possibly there is an uprated rubber one.
    Camden, Sydney
    There are different sized mounts. Standard 1.6, GTI or Diesel.
    Diesel will probably be the easiest to get hold of in Tassie. You need the whole bigger bracket, not just the bigger insert.
    sydney
    you can get a poly insert that fills up the cavities in the rubber ones, and yes you should go for the later larger style mount, but also check your other mounts as excess movment will wear them out quicker than normal
    http://www.prothane.com/pages/productguide.html
    and i think gti imports has some??
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    syncro Guest
    Make sure that you use German mounts.
    Oct 2006
    Hobart, Tasmania
    I have the bigger engine mount that came out of a diesel i think its 72mm but im not totaly sure? the mount is german made and it is the only mount that is broken on the car. When i pulled the mount out of the car the person that put the rubber mount inside the metal cassing put it in upside down and the engine was hitting the body. The new mount i orderd broke when we were inserting it and i was wondering if there was something stronger i could use but the prothane website looks like a good option http://www.prothane.com/pages/productguide.html
    cheers luke
    1977 VW golf 3 door
    Gilera Runner 180cc
    Oct 2006
    sydney
    on the topic of those prophane mounts ive heard they are really good i heard that hey are noisy for 5000 ks then get quietter im looking into getting some for the beeza bc the strut mount need doin and the engine mount also needs doing
    I've only replaced my mount's twice. Once with standard replacement aftermarket brand ones & they sagged & **** themselves in one day & I properly installed them too.
    Then I replaced them with genuine VW mount's & have never had a problem since.
    My recommendation, use OEM diesel mount's. The diesel engine side mount can be alittle tricky to insert too without damaging the housing but it can be done with some patience.
    Oct 2006
    Hobart, Tasmania
    Is the off centered hole in the engine mount rubber apposed to be pointing upwards or downwards. (this is the driver side mount im talking about)
    1977 VW golf 3 door
    Gilera Runner 180cc
    sydney
    the large cut out is towards the top
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  3. squeaky engine mounts
    By tommymac in forum Mk2 Golf & Jetta
    Last Post: 27-06-2006, 07:54 AM
  4. Engine mounts and brake discs
    By hiho in forum Mk1 Golf
    Last Post: 18-04-2006, 09:38 PM
  5. Urethane bushes and engine mounts
    By Bluerex in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 06-06-2005, 08:33 AM
